When you see a join-request but no join-accept, this usually means that the join-request is not accepted. Please refer to the (Application Server and / or Network Server) logs for more information. When it tells you that the device was not found, then it means you still need to add the device (e.g. wrong DevEUI), in case you see a MIC failure, then it means the key is incorrect.
Resolved!
The appKey must be inserted in arduino without empty spaces for example instead of putting “b7 d0 3e f4 c6 86 5b 40 62 fd 0f dd 98 14 83 bb” you must put “b7d03ef4c6865b4062fd0fdd981483bb” and in MSB format.
Furthermore “LoRaWAN MAC version” only goes with 1.0.X with 1.1.0 NOT going.
Hi Fabio, i have the same problem, i only receive “joinrequest” paquet. But i can’t user your solution because i use manufacured devices with AppKey inside.
Hi brocaar, in network server log i find this message: error=“join-request to join-server error: http post error: Post http://localhost:1883: read tcp [::1]:49026->[::1]:1883: read: connection reset by peer”
you can enter the key manually on the server instead of generating one
if you don’t have instructions on lorawan mac version you could do some tests
for example put the key in msb and wan mac version 1.0.1 if it doesn’t work change in lsb
otherwise change wan version 1.1.0 and try again
I advise you to take the tests in otaa not in abp so the key is only 1
as it should which you can put 0 or a series of 0 or leave it empty but I recommend a 0 to avoid problems
I have solved this in the absence of documentation that is understandable for me and so now I have created my documentation.
let me know if you need more help
