"JoinRequest" received in Gateway Lorawan Frames but not in device Lorawan frames
In Gateway Lorawan frames:
This is the DevEUI I’m creating the device with. I’m making sure is the right DevEUI, and it also matches the DevEUI in the image above:
In Device Lorawan frames I don’t see any frames:
According to the documentation, this issue might be a symptom of wrong DevEUI configured, but I’m making sure this number is correct (as seen above):
https://www.chirpstack.io/project/guides/connect-device/
What am I missing?
Any help is appreciated!
What does the device data tab show?
Hi broccar,
Device data tab shows no data as well:
Then I don’t know. Did you look at the server log output?
Hello Brocaar; I am also facing same issue; Please find the log from server.
Jan 06 04:40:34 ip-172-31-45-14 chirpstack-network-server[19443]: time=“2022-01-06T04:40:34.395068203Z” level=info msg=“gateway/mqtt: uplink frame received” gateway_id=7276ff0039040458 uplink_id=de2a7885-4759-495c-99b4-d88962cc5397
Jan 06 04:40:34 ip-172-31-45-14 chirpstack-network-server[19443]: time=“2022-01-06T04:40:34.595967084Z” level=info msg=“uplink: frame(s) collected” ctx_id=4b523591-bd28-437b-bbff-b43a21b5525f mtype=UnconfirmedDataUp uplink_ids="[de2a7885-4759-495c-99b4-d88962cc5397]"
Jan 06 04:40:34 ip-172-31-45-14 chirpstack-network-server[19443]: time=“2022-01-06T04:40:34.596349408Z” level=error msg=“uplink: processing uplink frame error” ctx_id=4b523591-bd28-437b-bbff-b43a21b5525f error=“get device-session error: object does not exist”
I found the issue! I was assigning the application to a “Service Profile” that the gateway did not belong to. I made sure that the gateway and the device application were under the same service profile, and it worked!
Regards
Abel
