I want to access the chirpstack Bridge configuration file to configure that. I installed its ipk file but when I enter :
cat /etc/chirpstack-gateway-bridge/chirpstack-gateway-bridge.toml
to access that, it says No such file or directory
even when I run
chirpstack-gateway-bridge configfile > chirpstack-gateway-bridge.toml
to generate a new configuration file, it says: Command not found.
I would appreciate it if someone could advise me how I can access that file to configure.
Thank you very much
I have made some updates to the Kerlink documentation, could you try again:
https://www.chirpstack.io/gateway-bridge/gateway/kerlink/#kerlink-keros-based-gateways
