I think you configured LoRa Server to only enable a sub-set of channels? LoRa Server tries to re-configure your device to a different set of channels and your devices does not ACK this change. That is all I can see from the above information.
Follow on question. We are seeing this issue where a 1.0.2 node with ADR off operating in US902-928 is not acking the channel mask request. It appears that when ADR is off in the NODE MAC then the node MAC code is expecting the server to respond with TXPower/DR with FF’s and the server is responding with 1’s.
Consequently, the node is not acking the channel mask request and the server continues to issue the channel mask after every uplink.
Orne: Is this a known issue? Should the server respond with TX Power/DR FF’s instead of 1’s? If it did the node would ack the channel mask and presumably the server would stop sending.
Even when adr is turned off on the device, it should still acknowledge any valid channel-mask. This is needed to move an US device from 64 to 8 channels.
When it doesn’t ack, then I would consider this as a bug in the device firmware.
The standard is certainly ambiguous at best. It basically doesn’t clearly specify how to properly deal with this situation. Consequently, the node/server implementors have to agree. In this case the stack force node side code is expecting FF’s for TX Power/DR and if it’s not FF’s then it doesn’t acknowledge the channel mask.
I think we’ll just work around it in the node for now.
we also get level=warning msg="link_adr request not acknowledged" channel_mask_ack=true data_rate_ack=false dev_eui=xxxxxxxxxxxxxxxx power_ack=truewarning message in LoRaServer Logs
sometimes when we started multiple nodes some nodes not sending up-links to the server sending JoinRequest JoinAccept
- Device Version:1.1.x
- ISM band: EU433MHz
- ADR: ON.
- Tx Data rate: DR_0.
- Bandwidth:125Khz.
- Min DataRate: 0
- Max DataRate: 7
- Max EIRP: 16
Check in previous downlink what the LinkADRReq mac-command contains as data-rate. In case this is a valid data-rate, then this could be an issue with your device firmware.
