Greetings,
It has been a really long time since my last post. I recently picked up the efforts again to start an Open Source LoRaWAN network for my community. But I am faced with some troubles.
With the Server:
I completely setup a fresh server blade on Ubuntu 18.04 and did the usual sudo apt update && sudo apt upgrade
followed by the steps highlight in each guide for Network Server and Application Server. Right out of the gate I am having issues in the Live LoRaWAN Frames section. I get the rapid flicker “Not Connected to WebSocket API
My Redis is currently 5.4.0.4
With the Gateway:
I have a Tektelic Kona Macro (actually I have 5) and I have updated it to the latest BSP after following the steps listed on the Tektelic Knowledge Base. I have also followed the guides from Chirpstack about uploading the .ipk
file and installing it. I edited the config file to point @ 127.0.0.1
with the ports set to 1700
. Nothing is connecting. So I went to TTN and created an account and set up a Gateway following their guides and it worked. I did this to rule out the gateway not being able to connect or transmit. So there is something wrong in the configurations for sure. So I set things back to point at my Chirpstack Server and still nothing. I even followed a step suggested by what I think is an admin to opkg remove tektelic-mqtt
. Still nothing.
Now then, I am asking for a little bit of help here. Keep in mind I am not expert at this but I have some working knowledge of the subject. I am just a dude who needs help, helping his community.
Cheers,
