loraserver is not getting my data from gateway.
But Gateway sends data perfectly.please check the lora-gateway-bridge log
INFO[0252] gateway: received udp packet from gateway addr="127.0.0.1:44562" protocol_version=2 type=PushData
INFO[0252] gateway: rxpk packet received addr="127.0.0.1:44562" data="gDQLbwOAEAAFpzXE2vZHQ74=" mac=b827ebfffec3XXXX
INFO[0252] gateway: sending udp packet to gateway addr="127.0.0.1:44562" protocol_version=2 type=PushACK
INFO[0252] backend: publishing packet qos=0 topic=gateway/b827ebfffec3XXXX/rx
TCPDUMP result from gateway
.................%1..'......{"rxpk":[{"tmst":1121181515,"chan":2,"rfch":1,"freq":868.500000,"stat":1,"modu":"LORA ","datr":"SF7BW125","codr":"4/5","lsnr":7.2,"rssi":-106,"size":17,"data":"gDQLbwOAEAAFpzXE2vZHQ74="}]}
11:15:52.485779 IP localhost.1700 > localhost.44562: UDP, length 4
But when i check loraserver and lora-app-server log, there is no change in the screen
loraserver
INFO[0000] backend/gateway: connected to mqtt server
INFO[0000] backend/gateway: subscribing to rx topic qos=0 topic=gateway/+/rx
INFO[0000] backend/gateway: subscribing to stats topic qos=0 topic=gateway/+/stats
INFO[0000] migrations applied count=0
INFO[0000] starting api server bind="0.0.0.0:8000" ca-cert= tls-cert= tls-key=
INFO[0000] starting downlink device-queue scheduler
INFO[0097] finished unary call with code OK grpc.code=OK grpc.method=GetDevice grpc.service=ns.NetworkServerService grpc.start_time="2018-08-21T11:25:18+05:30" grpc.time_ms=0.646 peer.address="127.0.0.1:59492" span.kind=server system=grpc
INFO[0099] finished unary call with code OK grpc.code=OK grpc.method=GetDeviceProfile grpc.service=ns.NetworkServerService grpc.start_time="2018-08-21T11:25:20+05:30" grpc.time_ms=0.751 peer.address="127.0.0.1:59492" span.kind=server system=grpc
INFO[0102] finished unary call with code OK grpc.code=OK grpc.method=GetGateway grpc.service=ns.NetworkServerService grpc.start_time="2018-08-21T11:25:23+05:30" grpc.time_ms=2.783 peer.address="127.0.0.1:59492" span.kind=server system=grpc
INFO[0108] backend/gateway: publishing tx packet qos=0 topic=gateway/b827ebfffecXXXX /tx
INFO[0108] finished unary call with code OK grpc.code=OK grpc.method=SendProprietaryPayload grpc.service=ns.NetworkServerService grpc.start_time="2018-08-21T11:25:29+05:30" grpc.time_ms=1.139 peer.address="127.0.0.1:59492" span.kind=server system=grpc
Lora-app-server
system=grpc
INFO[0094] finished client streaming call grpc.code=OK grpc.method=StreamFrameLogsForGateway grpc.service=ns.NetworkServerService grpc.time_ms=0.02 span.kind=client system=grpc
INFO[0094] finished unary call with code OK grpc.code=OK grpc.method=Get grpc.service=api.OrganizationService grpc.start_time="2018-08-21T11:25:24+05:30" grpc.time_ms=3.13 peer.address="127.0.0.1:59752" span.kind=server system=grpc
INFO[0099] gateway ping created dr=0 frequency=86800000 gateway_mac=b827ebfffecXXXX id=429
INFO[0099] finished client unary call grpc.code=OK grpc.method=SendProprietaryPayload grpc.service=ns.NetworkServerService grpc.time_ms=1.78 span.kind=client system=grpc
INFO[0099] gateway ping sent to network-server gateway_mac=b827ebfffecXXXX id=429
INFO[0099] gateway updated mac=b827ebfffecXXXX name=XX-LoRa-Gateway
It clearly shows that, data is out from gateway,
Even i tried subscribing to mqtt topics from server side,but still no response for mqtt topics also.
Please help me to resolve this!
