I have been trying to get the LoRaGo PORT (which is supposedly supported) to work on my Raspberry Pi 3 with the base version of GatewayOS 3.6.0 to no avail. I have found a close issue on GitHub that simply stated that the issue could not be reproduced. I opened another issue there, but decided to also ask the question here in case anyone has any more ideas.
No LEDs start on the device whatsoever. I have configured it using gateway-config and even tried setting the reset pin to a few that I found online (22 and 25 respectively), but that did not help either. Running chirpstack-concentratord-sx1301
yields the following error:
2022-09-19 09:33:42,671 INFO [libconcentratord::reset] Configuring reset pin, chip: 0, pin: 17
2022-09-19 09:33:42,671 INFO [chirpstack_concentratord_sx1301::cmd::root] Starting Concentratord SX1301 (version: 3.3.2, docs: https://www.chirpstack.io/concentratord/)
2022-09-19 09:33:42,671 INFO [libconcentratord::reset] Triggering concentrator reset
2022-09-19 09:33:42,871 INFO [chirpstack_concentratord_sx1301::concentrator] Setting spi device path, spidev_path: /dev/spidev0.0
2022-09-19 09:33:42,872 INFO [chirpstack_concentratord_sx1301::concentrator] Setting board configuration, lorawan_public: true, clock_source: 1
2022-09-19 09:33:42,872 INFO [chirpstack_concentratord_sx1301::concentrator] Setting up concentrator radios
2022-09-19 09:33:42,872 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257
2022-09-19 09:33:42,872 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257
2022-09-19 09:33:42,872 INFO [chirpstack_concentratord_sx1301::concentrator] Setting up concentrator channels
2022-09-19 09:33:42,872 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000
2022-09-19 09:33:42,872 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
2022-09-19 09:33:42,873 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0
2022-09-19 09:33:42,873 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000
2022-09-19 09:33:42,873 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000
2022-09-19 09:33:42,873 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0
2022-09-19 09:33:42,873 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000
2022-09-19 09:33:42,873 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000
2022-09-19 09:33:42,873 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
2022-09-19 09:33:42,873 INFO [chirpstack_concentratord_sx1301::concentrator] Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
2022-09-19 09:33:42,874 INFO [chirpstack_concentratord_sx1301::concentrator] Starting the concentrator
thread 'main' panicked at 'called `Result::unwrap()` on an `Err` value: "lgw_start failed"', chirpstack-concentratord-sx1301/src/main.rs:108:80
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
The reset pin here stays the same (always at 17) regardless of what I type in the concentratord config. I saw some instructions somewhere that required you to execute the /etc/init.d/sx1301-reset
command, but that doesn’t appear to be available on my install.
/var/log/messages shows the following output:
Sep 19 09:03:58 raspberrypi3 user.info chirpstack-concentratord-sx1301[942]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000
Sep 19 09:03:58 raspberrypi3 user.info chirpstack-concentratord-sx1301[942]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Sep 19 09:03:58 raspberrypi3 user.info chirpstack-concentratord-sx1301[942]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0
Sep 19 09:03:58 raspberrypi3 user.info chirpstack-concentratord-sx1301[942]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000
Sep 19 09:03:58 raspberrypi3 user.info chirpstack-concentratord-sx1301[942]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000
Sep 19 09:03:58 raspberrypi3 user.info chirpstack-concentratord-sx1301[942]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0
Sep 19 09:03:58 raspberrypi3 user.info chirpstack-concentratord-sx1301[942]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000
Sep 19 09:03:58 raspberrypi3 user.info chirpstack-concentratord-sx1301[942]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000
Sep 19 09:03:58 raspberrypi3 user.info chirpstack-concentratord-sx1301[942]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Sep 19 09:03:58 raspberrypi3 user.info chirpstack-concentratord-sx1301[942]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
Sep 19 09:03:58 raspberrypi3 user.info chirpstack-concentratord-sx1301[942]: Starting the concentrator
Sep 19 09:04:00 raspberrypi3 user.err chirpstack-gateway-bridge[592]: time="2022-09-19T09:04:00.913589202Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Sep 19 09:04:04 raspberrypi3 user.err chirpstack-gateway-bridge[592]: time="2022-09-19T09:04:04.427206744Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Sep 19 09:04:07 raspberrypi3 user.err chirpstack-gateway-bridge[592]: time="2022-09-19T09:04:07.940586578Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Sep 19 09:04:08 raspberrypi3 user.err monit[430]: 'chirpstack-concentratord' process is not running
Sep 19 09:04:08 raspberrypi3 user.info monit[430]: 'chirpstack-concentratord' trying to restart
Sep 19 09:04:08 raspberrypi3 user.info monit[430]: 'chirpstack-concentratord' start: '/etc/init.d/chirpstack-concentratord start'
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Configuring reset pin, chip: 0, pin: 0
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Starting Concentratord SX1301 (version: 3.3.2, docs: https://www.chirpstack.io/concentratord/)
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Triggering concentrator reset
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Setting spi device path, spidev_path: /dev/spidev0.0
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Setting board configuration, lorawan_public: true, clock_source: 1
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Setting up concentrator radios
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Setting up concentrator channels
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
Sep 19 09:04:08 raspberrypi3 user.info chirpstack-concentratord-sx1301[949]: Starting the concentrator
Sep 19 09:04:11 raspberrypi3 user.err chirpstack-gateway-bridge[592]: time="2022-09-19T09:04:11.453818289Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
Sep 19 09:04:14 raspberrypi3 user.err chirpstack-gateway-bridge[592]: time="2022-09-19T09:04:14.966808536Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial un
I would really appreciate some help here.
