LoRaServer on a Pi with PiSupply IoT LoRa Gateway HAT
Using:
Log into the Pi and run sudo gateway-config to Setup LoRa concentrator shield. Choose RAK831 as the Pi Supply Hat uses a RAK833 (PCIE - SPI) module. And choose your frequency plan (EU868 for me).
Now change the reset pin to the correct one used by this hat:
sudo nano /etc/default/lora-packet-forwarder
and change to
# reset pin
CONCENTRATOR_RESET_PIN=22
Restart the Pi
To see if the gateway is working or not I had to log into the LoRa Server web UI and run through all the screens and create instances of everything (I’m missing some documentation what exactly to do). Then finally I was able to register the gateway using the EUI I obtained from cat /etc/lora-packet-forwarder/global_conf.json.
