I correctly installed the Loraserver and Lora-app-server on a small linux machine (thank’s Brocaar).
Now i want to install the software on an Amazon remote machine (AWS)
I followed the same steps and it seems that everything went well but I can not transmit any packets from the gateway lora.
Do you have any ideas?
Thank’s
Silvano
Yes, i have set the firewall rules.
Could you share with us the logs of both loraserver and loraappserver?
sure!
ubuntu@ip-172-31-44-43:~$ journalctl -u loraserver -f -n 50
– Logs begin at Wed 2018-02-07 08:10:30 UTC. –
Feb 07 08:10:35 ip-172-31-44-43 systemd[1]: Started LoRa Server.
Feb 07 08:10:35 ip-172-31-44-43 loraserver[1316]: time=“2018-02-07T08:10:35Z” level=info msg=“starting LoRa Server” band=EU_863_870 docs=“https://docs.loraserver.io/” net_id=010203 version=0.23.3
Feb 07 08:10:35 ip-172-31-44-43 loraserver[1316]: time=“2018-02-07T08:10:35Z” level=info msg=“setup redis connection pool” url=“redis://localhost:6379”
Feb 07 08:10:35 ip-172-31-44-43 loraserver[1316]: time=“2018-02-07T08:10:35Z” level=info msg=“connecting to postgresql”
Feb 07 08:10:35 ip-172-31-44-43 loraserver[1316]: time=“2018-02-07T08:10:35Z” level=error msg=“ping database error, will retry in 2s: dial tcp 127.0.0.1:5432: getsockopt: connection refused”
Feb 07 08:10:37 ip-172-31-44-43 loraserver[1316]: time=“2018-02-07T08:10:37Z” level=info msg=“backend/gateway: connecting to mqtt broker” server=“tcp://localhost:1883”
Feb 07 08:10:37 ip-172-31-44-43 loraserver[1316]: time=“2018-02-07T08:10:37Z” level=info msg=“configuring join-server client” ca_cert= server=“http://localhost:8003” tls_cert= tls_key=
Feb 07 08:10:37 ip-172-31-44-43 loraserver[1316]: time=“2018-02-07T08:10:37Z” level=info msg=“no network-controller configured”
Feb 07 08:10:37 ip-172-31-44-43 loraserver[1316]: time=“2018-02-07T08:10:37Z” level=info msg=“applying database migrations”
Feb 07 08:10:37 ip-172-31-44-43 loraserver[1316]: time=“2018-02-07T08:10:37Z” level=info msg=“backend/gateway: connected to mqtt server”
Feb 07 08:10:37 ip-172-31-44-43 loraserver[1316]: time=“2018-02-07T08:10:37Z” level=info msg=“backend/gateway: subscribing to rx topic” topic=gateway/+/rx
Feb 07 08:10:37 ip-172-31-44-43 loraserver[1316]: time=“2018-02-07T08:10:37Z” level=info msg=“backend/gateway: subscribing to stats topic” topic=gateway/+/stats
Feb 07 08:10:37 ip-172-31-44-43 loraserver[1316]: time=“2018-02-07T08:10:37Z” level=info msg=“migrations applied” count=0
Feb 07 08:10:37 ip-172-31-44-43 loraserver[1316]: time=“2018-02-07T08:10:37Z” level=info msg=“starting api server” bind=“0.0.0.0:8000” ca-cert= tls-cert= tls-key=
Feb 07 08:10:37 ip-172-31-44-43 loraserver[1316]: time=“2018-02-07T08:10:37Z” level=info msg=“starting gateway api server” bind=“0.0.0.0:8002” ca-cert= tls-cert= tls-key=
Feb 07 08:10:37 ip-172-31-44-43 loraserver[1316]: time=“2018-02-07T08:10:37Z” level=info msg=“starting downlink device-queue scheduler”
ubuntu@ip-172-31-44-43:~$ journalctl -u lora-app-server -f -n 50
Feb 07 08:10:37 ip-172-31-44-43 systemd[1]: Started LoRa App Server.
Feb 07 08:10:38 ip-172-31-44-43 lora-app-server[1388]: time=“2018-02-07T08:10:38Z” level=info msg=“starting LoRa App Server” docs=“https://docs.loraserver.io/” version=0.17.1
Feb 07 08:10:38 ip-172-31-44-43 lora-app-server[1388]: time=“2018-02-07T08:10:38Z” level=info msg=“connecting to postgresql”
Feb 07 08:10:38 ip-172-31-44-43 lora-app-server[1388]: time=“2018-02-07T08:10:38Z” level=info msg=“setup redis connection pool”
Feb 07 08:10:38 ip-172-31-44-43 lora-app-server[1388]: time=“2018-02-07T08:10:38Z” level=info msg=“handler/mqtt: connecting to mqtt broker” server=“tcp://localhost:1883”
Feb 07 08:10:38 ip-172-31-44-43 lora-app-server[1388]: time=“2018-02-07T08:10:38Z” level=info msg=“applying database migrations”
Feb 07 08:10:38 ip-172-31-44-43 lora-app-server[1388]: time=“2018-02-07T08:10:38Z” level=info msg=“handler/mqtt: connected to mqtt broker”
Feb 07 08:10:38 ip-172-31-44-43 lora-app-server[1388]: time=“2018-02-07T08:10:38Z” level=info msg=“handler/mqtt: subscribling to tx topic” topic=application/+/node/+/tx
Feb 07 08:10:38 ip-172-31-44-43 lora-app-server[1388]: time=“2018-02-07T08:10:38Z” level=info msg=“migrations applied” count=0
Feb 07 08:10:38 ip-172-31-44-43 lora-app-server[1388]: time=“2018-02-07T08:10:38Z” level=info msg=“starting application-server api” bind=“0.0.0.0:8001” ca-cert= tls-cert= tls-key=
Feb 07 08:10:38 ip-172-31-44-43 lora-app-server[1388]: time=“2018-02-07T08:10:38Z” level=info msg=“starting join-server api” bind=“0.0.0.0:8003” ca_cert= tls_cert= tls_key=
Feb 07 08:10:38 ip-172-31-44-43 lora-app-server[1388]: time=“2018-02-07T08:10:38Z” level=info msg=“starting client api server” bind=“0.0.0.0:8080” tls-cert=/etc/lora-app-server/certs/http.pem tls-key=/etc/lora-app-server/certs/http-key.pem
Feb 07 08:10:38 ip-172-31-44-43 lora-app-server[1388]: time=“2018-02-07T08:10:38Z” level=info msg=“registering rest api handler and documentation endpoint” path=/api
SOLVED!
was an error on Gateway bridge configuration.
Thank’s
