Mandatory TLS Issue
I place the application server behind Nginx, so the user<->server TLS termination is being done by Nginx, and I don’t need an additional layer of encryption between the application server and Nginx on the same host.
I get a fatal error “tls cert and tls key must be set for the external api” when trying to start the application server without a certificate.
I suggest to document that it is not recommended to use the service by its own without TLS, and remove that limitation.
Thank you.
Please see the documentation: https://www.loraserver.io/lora-app-server/install/config/
The web-interface and public api ([application_server.public_api]) must be secured by a TLS certificate and key, as this allows to run the gRPC and RESTful JSON api together on one port.
FYI: There is currently an open pull-request to make this optional: https://github.com/brocaar/lora-app-server/pull/235. I’m waiting with merging this in until https://go-review.googlesource.com/c/net/+/112997 has been merged.
