I’ve successfully migrated loraserver to chirpstack under docker-compose, but lost all my devices and such. Is there a method to export the data in the loraserver database into chirpstack? I can still bring up the loraserver container.
I’m a mySQL guy, and have extremely limited knowledge of postgres, so if there needs to be any queries from the command line, they’d need to be complete commands
There should be no need to loose all your data. The only think you need to do is update the image names from loraserver/... to chirpstack/... as outlined in the announcement. After that you need to make sure to update the volumes, e.g.:
(and rename the configuration/loraserver foloder to `configuration/chirpstack-network-server).
Of course this applies to the application-server, gateway-bridge and geolocation-server services. You should not update your database configuration. It is fine to leave these set to loraserver_ns and loraserver_as, unless you have renamed these within PostgreSQL.
OK. I had copied the loraserver-docker directory to chirpstack-docker, renamed everything, then spun it up. Apparently docker takes the directory it’s started in as part of what makes a container unique or something.
I went back and renamed the original directory to loraserver-docker.org and chirpstack to loraserver-docker, spun it up, and it found the original database with all my devices.
Apparently being pro-active about preserving my old environment was not the winning course of action.
Hrm. Actually, when I drill down into any gateway, application, or device profile, once I select the gateway, or whatever I get a pop-up that says context deadline exceeded (code: 2) that disappears after a few seconds, and then the area where that would be displayed is blank.
When you change the name of a service in the docker-compose file, then this also changes the hostname. I suggest for existing setups, you keep the service-name as is (only change the container image and config paths).
