I have a multitech AEP conduit in packet forwarder mode and chirpstack gateway bridge installed in our server. I have two end devices with me, one is from winext and other is from Digital matter(sensor node).
The winext GPS device sends location information every time the switch in it is triggered consistently and could see all the packets in the gateway bridge using the below command
sudo tcpdump -AUq port 1700
Below is the packet seen in the Gateway bridge
[.{"rxpk": [{"tmst":3229677588,"chan":3,"rfch":0,"freq":902.900000,"stat":1,"modu":"LORA","datr":"SF9BW125","codr":"4/5","lsnr":6.5,"rssi":-57,"size":14,"data":"QKo/qQEA1gAerkz1akQ="}]
But when the sensor node is triggered, we are missing most of the packets and unable to see any packets in the gateway bridge most of the time. Is this a problem with the packet forwarder or the end device itself. Can someone point out what coud be the issue here?
