This is a community based support platform, you can not expect people to respond within hours after posting your question. Be a bit more patient please
To answer your question, please note that the # character is also used for comments. You might need to escape it so that it is not interpreted, e.g. \#. Thus:
I have tested it with \# but the loraserver or lora app server can’t be active in this case.
Actually I can run web ui in wmware but in main system I have above error.
Tanks, for quick answer.
l use dsn=“postgres://loraserver_ns:dbpassword@localhost/loraserver_ns?sslmode=disable" in etc/loraserver/loraserver.toml.
dsn=“postgres://loraserver_as:dbpassword@localhost/loraserver_as?sslmode=disable" and jw_secure=“dbpassword” in /etc/lora-app-server/lora-app-server.toml and then restart both of them and then it work.
tnx.
