Hi community,
We’re testing a setup like the one in this diagram:
We started with the gateways in AU915, and all was good. When we connected a GW in region US915 we started noticing in the GUI that gateways appear randomly available or unavailable. From looking and the NS logs and reading in the forum I understand that maybe the issue is that since the 2 NS are consuming from the same MQTT, one is winning. These are some logs from the US915 NS, but showing the ID of one AU915 gateway:
time="2021-10-14T16:29:33.704998113Z" level=info msg="gateway/mqtt: gateway stats packet received" gateway_id=d4adbdfffe9e0345 stats_id=bdf2ae05-0ab9-44f7-97a5-646724ba7b04
time="2021-10-14T16:29:33.70652764Z" level=error msg="gateway: handle gateway stats error" ctx_id=bdf2ae05-0ab9-44f7-97a5-646724ba7b04 error="update gateway state error: object does not exist"
We’re using the docker solution, with mosquitto mqtt. From other posts I see the recommendation of enabling shared topics. Is that the solution for this scenario, and if so how can I enable them in mosquitto.conf?
Thanks in advance,
chabral.
