v0.26.1
level=error msg="processing rx packet error: get device-session error: device-session does not exist or invalid fcnt or mic" data_base64=QHhWNBKAjQCXn+5GGRqxl
Hi, I am relatively new to LoRa and I need some help to get my setup running, I am sorry if this is the wrong place. Now, before you close my issue and direct me where this has already been answered, let me tell you that I have read those threads and they did not help.
Join Method: ABP
I have created a device in the lora-app, took the generated device address, NetworkSK, AppSK and put that configuration in my test node.
When I send a packet from the node, I can see loraserver receiving it from the gateway-bridge but it seems like it cannot process/decode/decrypt it for some reason.
What I have tried(because the error message mentioned something about the frame counter being out of sync with the node) was to create a new node and disable the frame counter. This didn’t change much and loraserver still emits the same error.
Help is very appreciated :).
( I have also looked into the byte order of the addresses )
