Hi!
Faced similar problem on update loraserver ver.2 to ver.3:
[No data after upgrading from v2 to v3](http://upgrading-from-v2-to-v3 issue)
Now I am trying to update from old loraserver
to latest version of chirpstack
chirpstack-application-server
and chirpstack-network-server
built from latest commit of github repo while chirpstack-gateway-bridge
taken as docker image chirpstack/chirpstack-gateway-bridge:3
The problem is that chirpstack-gateway-bridge
send to following topics:
time="2020-04-12T16:13:18Z" level=info msg="integration/mqtt: publishing event" event=stats qos=0 stats_id=fdae0f5c-7001-45aa-9bf3-ef58a2430b04 topic=gateway/aa555a0000000005/event/stats
time="2020-04-12T16:13:40Z" level=info msg="integration/mqtt: publishing event" event=up qos=0 topic=gateway/aa555a0000000005/event/up uplink_id=52e029a0-9fcb-4b1c-a233-eb4ed3652fce
while chirpstack-network-server
listens for following topics:
time="2020-04-12T16:07:56Z" level=info msg="gateway/mqtt: subscribing to rx topic" qos=0 topic=gateway/+/rx
time="2020-04-12T16:07:56Z" level=info msg="gateway/mqtt: subscribing to stats topic" qos=0 topic=gateway/+/stats
time="2020-04-12T16:07:56Z" level=info msg="backend/gateway: subscribing to ack topic" qos=0 topic=gateway/+/ack
so it doesn’t hear anything from chirpstack-network-server
After switching back to lora-gateway-bridge
it started to work but I don’t see any packets in data
tab of web interface. Only in frames
tab:
Looks like after upgrading to chirpstack
it switched back for compatibility with lora-gateway-bridge
version 2.
But I guess there is not true. So what did I miss?
