After updating loraserver
from 2.xx to latest 3.2.1 it stopped to receive any events published from lora_gatewaybridge
Before updating it worked in following way:
msg="backend/gateway: connected to mqtt server"
msg="gateway/mqtt: subscribing to rx topic" qos=0 topic=gateway/+/rx
msg="gateway/mqtt: subscribing to stats topic" qos=0 topic=gateway/+/stats
msg="backend/gateway: subscribing to ack topic" qos=0 topic=gateway/+/ack
msg="migrations applied" count=0
msg="starting api server" bind="0.0.0.0:8000" ca-cert= tls-cert= tls-key=
msg="starting downlink device-queue scheduler"
msg="starting multicast scheduler"
So it was able to receive gatewaybridge's
events:
msg="backend: publishing packet" qos=0 topic=gateway/aa555a0000000005/stats
msg="backend: publishing packet" qos=0 topic=gateway/aa555a0000000005/rx
But after update it does just this:
msg="gateway/mqtt: connecting to mqtt broker" server="tcp://lora_mosquitto:1883"
msg="connecting to geolocation-server" ca_cert= server="lora_geoserver:8005" tls_cert= tls_key=
msg="gateway/mqtt: subscribing to gateway event topic" qos=0 topic=gateway/+/event/+
msg="configuring join-server client" ca_cert= server="http://lora_appserver:8003" tls_cert= tls_key=
msg="api: starting network-server api server" bind="0.0.0.0:8000" ca-cert= tls-cert= tls-key=
E.g. it subscribed for completely another topics.
Does it mean that I should update gatewaybridge software too?
What did I miss? How to update a software after more than year delay?)
