Hello guys, I’m trying to send command via mqtt to my device via abp. Unfortunately the device is not receiving. If I use otaa, I receive the commands. I’m using Au 915 standard. Something strange is that the downlink counter is incrementing even without sending messages.
LOG:
chirpstack-application-server_1 | time=“2020-06-08T14:57:25Z” level=info msg=“integration/mqtt: data-down payload received” topic=application/1/device/2c1361db209ac960/tx
chirpstack-network-server_1 | time=“2020-06-08T14:57:25Z” level=info msg=“finished unary call with code OK” ctx_id=756d9d74-ce50-444f-9038-4a098c46447e grpc.code=OK grpc.method=GetNextDownlinkFCntForDevEUI grpc.service=ns.NetworkServerService grpc.start_time=“2020-06-08T14:57:25Z” grpc.time_ms=5.572 peer.address=“172.20.0.8:47052” span.kind=server system=grpc
chirpstack-application-server_1 | time=“2020-06-08T14:57:25Z” level=info msg=“finished client unary call” ctx_id="" grpc.code=OK grpc.ctx_id=756d9d74-ce50-444f-9038-4a098c46447e grpc.duration=11.47424ms grpc.method=GetNextDownlinkFCntForDevEUI grpc.service=ns.NetworkServerService span.kind=client system=grpc
chirpstack-network-server_1 | time=“2020-06-08T14:57:25Z” level=info msg=“device-queue item created” ctx_id=63a7c19d-29ec-49cb-8fb0-e81539d597b3 dev_eui=2c1361db209ac960 f_cnt=29
chirpstack-network-server_1 | time=“2020-06-08T14:57:25Z” level=info msg=“finished unary call with code OK” ctx_id=63a7c19d-29ec-49cb-8fb0-e81539d597b3 grpc.code=OK grpc.method=CreateDeviceQueueItem grpc.service=ns.NetworkServerService grpc.start_time=“2020-06-08T14:57:25Z” grpc.time_ms=21.066 peer.address=“172.20.0.8:47052” span.kind=server system=grpc
chirpstack-application-server_1 | time=“2020-06-08T14:57:25Z” level=info msg=“finished client unary call” ctx_id=075dc55a-0a3b-4bea-bc1e-dd12830d7576 grpc.code=OK grpc.ctx_id=63a7c19d-29ec-49cb-8fb0-e81539d597b3 grpc.duration=22.426739ms grpc.method=CreateDeviceQueueItem grpc.service=ns.NetworkServerService span.kind=client system=grpc
chirpstack-application-server_1 | time=“2020-06-08T14:57:25Z” level=info msg=“downlink device-queue item handled” confirmed=true dev_eui=2c1361db209ac960 f_cnt=29
chirpstack-gateway-bridge_1 | time=“2020-06-08T14:57:30Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 stats_id=71675b85-2ad1-4245-b991-7a3b4adcbd34 topic=gateway/b827ebfffe0cf2da/event/stats
chirpstack-network-server_1 | time=“2020-06-08T14:57:30Z” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=b827ebfffe0cf2da stats_id=71675b85-2ad1-4245-b991-7a3b4adcbd34
chirpstack-network-server_1 | time=“2020-06-08T14:57:30Z” level=info msg=“gateway updated” ctx_id=71675b85-2ad1-4245-b991-7a3b4adcbd34 gateway_id=b827ebfffe0cf2da
chirpstack-application-server_1 | time=“2020-06-08T14:57:30Z” level=info msg=“gateway updated” ctx_id=63cdb532-2ca7-4420-85dd-372662a7ca4f id=b827ebfffe0cf2da name=Rak831_Gateway
chirpstack-application-server_1 | time=“2020-06-08T14:57:30Z” level=info msg=“metrics saved” aggregation="[MINUTE HOURDAY MONTH]" ctx_id=63cdb532-2ca7-4420-85dd-372662a7ca4f name=“gw:b827ebfffe0cf2da”
chirpstack-application-server_1 | time=“2020-06-08T14:57:30Z” level=info msg=“finished unary call with code OK” ctx_id=63cdb532-2ca7-4420-85dd-372662a7ca4f grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2020-06-08T14:57:30Z” grpc.time_ms=10.655 peer.address=“172.20.0.3:33320” span.kind=server system=grpc
chirpstack-network-server_1 | time=“2020-06-08T14:57:30Z” level=info msg=“finished client unary call” ctx_id=71675b85-2ad1-4245-b991-7a3b4adcbd34 grpc.code=OK grpc.ctx_id=63cdb532-2ca7-4420-85dd-372662a7ca4f grpc.duration=13.425119ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
chirpstack-gateway-bridge_1 | time=“2020-06-08T14:57:53Z” level=info msg=“integration/mqtt: publishing event” event=up qos=0 topic=gateway/b827ebfffe0cf2da/event/up uplink_id=9722ddbd-0723-48df-ba7b-66b5d7458979
chirpstack-network-server_1 | time=“2020-06-08T14:57:53Z” level=info msg=“gateway/mqtt: uplink frame received” gateway_id=b827ebfffe0cf2da uplink_id=9722ddbd-0723-48df-ba7b-66b5d7458979
chirpstack-network-server_1 | time=“2020-06-08T14:57:53Z” level=info msg=“uplink: frame(s) collected” ctx_id=910d14d1-737d-4e1a-8a5a-fb5bf55d5bb0 mtype=UnconfirmedDataUp uplink_ids="[9722ddbd-0723-48df-ba7b-66b5d7458979]"
chirpstack-network-server_1 | time=“2020-06-08T14:57:53Z” level=info msg=“sent uplink meta-data to network-controller” ctx_id=910d14d1-737d-4e1a-8a5a-fb5bf55d5bb0 dev_eui=2c1361db209ac960
chirpstack-network-server_1 | time=“2020-06-08T14:57:53Z” level=info msg=“device gateway rx-info meta-data saved” ctx_id=910d14d1-737d-4e1a-8a5a-fb5bf55d5bb0 dev_eui=2c1361db209ac960
chirpstack-network-server_1 | time=“2020-06-08T14:57:53Z” level=info msg=“device-session saved” ctx_id=910d14d1-737d-4e1a-8a5a-fb5bf55d5bb0 dev_addr=00f87316 dev_eui=2c1361db209ac960
chirpstack-application-server_1 | time=“2020-06-08T14:57:53Z” level=info msg=“device last-seen and dr updated” ctx_id=7a085125-8da0-4440-a049-47943bb4509a dev_eui=2c1361db209ac960
chirpstack-network-server_1 | time=“2020-06-08T14:57:53Z” level=info msg=“finished client unary call” ctx_id=910d14d1-737d-4e1a-8a5a-fb5bf55d5bb0 grpc.code=OK grpc.ctx_id=7a085125-8da0-4440-a049-47943bb4509a grpc.duration=25.403594ms grpc.method=HandleUplinkData grpc.service=as.ApplicationServerService span.kind=client system=grpc
chirpstack-application-server_1 | time=“2020-06-08T14:57:53Z” level=info msg=“finished unary call with code OK” ctx_id=7a085125-8da0-4440-a049-47943bb4509a grpc.code=OK grpc.method=HandleUplinkData grpc.request.deadline=“2020-06-08T14:57:54Z” grpc.service=as.ApplicationServerService grpc.start_time=“2020-06-08T14:57:53Z” grpc.time_ms=18.512 peer.address=“172.20.0.3:33320” span.kind=server system=grpc
chirpstack-application-server_1 | time=“2020-06-08T14:57:53Z” level=info msg=“integration/mqtt: publishing message” ctx_id=7a085125-8da0-4440-a049-47943bb4509a qos=0 topic=application/1/device/2c1361db209ac960/rx
chirpstack-gateway-bridge_1 | time=“2020-06-08T14:57:53Z” level=info msg=“integration/mqtt: downlink frame received” downlink_id=910d14d1-737d-4e1a-8a5a-fb5bf55d5bb0 gateway_id=b827ebfffe0cf2da
chirpstack-network-server_1 | time=“2020-06-08T14:57:53Z” level=info msg=“device-queue item updated” ctx_id=910d14d1-737d-4e1a-8a5a-fb5bf55d5bb0 dev_eui=2c1361db209ac960 emit_at_time_since_gps_epoch="" f_cnt=29 is_pending=true timeout_after=“2020-06-08 14:57:53.565817067 +0000 UTC m=+1437.608179124”
chirpstack-network-server_1 | time=“2020-06-08T14:57:53Z” level=info msg=“adr request added to mac-command queue” ctx_id=910d14d1-737d-4e1a-8a5a-fb5bf55d5bb0 dev_eui=2c1361db209ac960 dr=2 nb_trans=1 req_dr=8 req_nb_trans=1 req_tx_power_idx=0 tx_power=0
chirpstack-network-server_1 | time=“2020-06-08T14:57:53Z” level=info msg=“pending mac-command block set” cid=LinkADRReq commands=2 ctx_id=910d14d1-737d-4e1a-8a5a-fb5bf55d5bb0 dev_eui=2c1361db209ac960
chirpstack-network-server_1 | time=“2020-06-08T14:57:53Z” level=info msg=“pending mac-command block set” cid=RXParamSetupReq commands=1 ctx_id=910d14d1-737d-4e1a-8a5a-fb5bf55d5bb0 dev_eui=2c1361db209ac960
chirpstack-network-server_1 | time=“2020-06-08T14:57:53Z” level=info msg=“gateway/mqtt: publishing gateway command” command=down downlink_id=910d14d1-737d-4e1a-8a5a-fb5bf55d5bb0 gateway_id=b827ebfffe0cf2da qos=0 topic=gateway/b827ebfffe0cf2da/command/down
chirpstack-network-server_1 | time=“2020-06-08T14:57:53Z” level=info msg=“downlink-frames saved” ctx_id=910d14d1-737d-4e1a-8a5a-fb5bf55d5bb0 token=37133
chirpstack-gateway-bridge_1 | time=“2020-06-08T14:58:00Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 stats_id=a1e028b3-6ea9-4754-a459-b6217e88a8d7 topic=gateway/b827ebfffe0cf2da/event/stats
chirpstack-network-server_1 | time=“2020-06-08T14:58:00Z” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=b827ebfffe0cf2da stats_id=a1e028b3-6ea9-4754-a459-b6217e88a8d7
chirpstack-network-server_1 | time=“2020-06-08T14:58:00Z” level=info msg=“gateway updated” ctx_id=a1e028b3-6ea9-4754-a459-b6217e88a8d7 gateway_id=b827ebfffe0cf2da
chirpstack-application-server_1 | time=“2020-06-08T14:58:00Z” level=info msg=“gateway updated” ctx_id=5dd28162-5e70-4d04-b23b-4acacebb75ea id=b827ebfffe0cf2da name=Rak831_Gateway
chirpstack-application-server_1 | time=“2020-06-08T14:58:00Z” level=info msg=“metrics saved” aggregation="[MINUTE HOURDAY MONTH]" ctx_id=5dd28162-5e70-4d04-b23b-4acacebb75ea name=“gw:b827ebfffe0cf2da”
chirpstack-application-server_1 | time=“2020-06-08T14:58:00Z” level=info msg=“finished unary call with code OK” ctx_id=5dd28162-5e70-4d04-b23b-4acacebb75ea grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2020-06-08T14:58:00Z” grpc.time_ms=27.455 peer.address=“172.20.0.3:33320” span.kind=server system=grpc
chirpstack-network-server_1 | time=“2020-06-08T14:58:00Z” level=info msg=“finished client unary call” ctx_id=a1e028b3-6ea9-4754-a459-b6217e88a8d7 grpc.code=OK grpc.ctx_id=5dd28162-5e70-4d04-b23b-4acacebb75ea grpc.duration=35.087985ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
chirpstack-gateway-bridge_1 | time=“2020-06-08T14:58:30Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 stats_id=07fc19b1-d147-475e-ae47-49b1d29eb362 topic=gateway/b827ebfffe0cf2da/event/stats
chirpstack-network-server_1 | time=“2020-06-08T14:58:30Z” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=b827ebfffe0cf2da stats_id=07fc19b1-d147-475e-ae47-49b1d29eb362
chirpstack-network-server_1 | time=“2020-06-08T14:58:30Z” level=info msg=“gateway updated” ctx_id=07fc19b1-d147-475e-ae47-49b1d29eb362 gateway_id=b827ebfffe0cf2da
chirpstack-application-server_1 | time=“2020-06-08T14:58:30Z” level=info msg=“gateway updated” ctx_id=d15ebf14-db9a-45b7-b666-45844cd3b3c3 id=b827ebfffe0cf2da name=Rak831_Gateway
chirpstack-network-server_1 | time=“2020-06-08T14:58:30Z” level=info msg=“finished client unary call” ctx_id=07fc19b1-d147-475e-ae47-49b1d29eb362 grpc.code=OK grpc.ctx_id=d15ebf14-db9a-45b7-b666-45844cd3b3c3 grpc.duration=63.859827ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
chirpstack-application-server_1 | time=“2020-06-08T14:58:30Z” level=info msg=“metrics saved” aggregation="[MINUTE HOURDAY MONTH]" ctx_id=d15ebf14-db9a-45b7-b666-45844cd3b3c3 name=“gw:b827ebfffe0cf2da”
chirpstack-application-server_1 | time=“2020-06-08T14:58:30Z” level=info msg=“finished unary call with code OK” ctx_id=d15ebf14-db9a-45b7-b666-45844cd3b3c3 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2020-06-08T14:58:30Z” grpc.time_ms=60.977 peer.address=“172.20.0.3:33320” span.kind=server system=grpc
chirpstack-gateway-bridge_1 | time=“2020-06-08T14:58:53Z” level=info msg=“integration/mqtt: publishing event” event=up qos=0 topic=gateway/b827ebfffe0cf2da/event/up uplink_id=5a456a83-39bd-4f09-9f70-1755da30a7c1
chirpstack-network-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“gateway/mqtt: uplink frame received” gateway_id=b827ebfffe0cf2da uplink_id=5a456a83-39bd-4f09-9f70-1755da30a7c1
chirpstack-network-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“uplink: frame(s) collected” ctx_id=9a1bb64f-b8f8-4b4c-84fd-fc33022896eb mtype=UnconfirmedDataUp uplink_ids="[5a456a83-39bd-4f09-9f70-1755da30a7c1]"
chirpstack-network-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“sent uplink meta-data to network-controller” ctx_id=9a1bb64f-b8f8-4b4c-84fd-fc33022896eb dev_eui=2c1361db209ac960
chirpstack-network-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“device gateway rx-info meta-data saved” ctx_id=9a1bb64f-b8f8-4b4c-84fd-fc33022896eb dev_eui=2c1361db209ac960
chirpstack-network-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“device-session saved” ctx_id=9a1bb64f-b8f8-4b4c-84fd-fc33022896eb dev_addr=00f87316 dev_eui=2c1361db209ac960
chirpstack-application-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“device last-seen and dr updated” ctx_id=d751047f-ba0b-4697-89c4-69e0d91282ab dev_eui=2c1361db209ac960
chirpstack-application-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“finished unary call with code OK” ctx_id=d751047f-ba0b-4697-89c4-69e0d91282ab grpc.code=OK grpc.method=HandleUplinkData grpc.request.deadline=“2020-06-08T14:58:54Z” grpc.service=as.ApplicationServerService grpc.start_time=“2020-06-08T14:58:53Z” grpc.time_ms=65.165 peer.address=“172.20.0.3:33320” span.kind=server system=grpc
chirpstack-application-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“integration/mqtt: publishing message” ctx_id=d751047f-ba0b-4697-89c4-69e0d91282ab qos=0 topic=application/1/device/2c1361db209ac960/rx
chirpstack-network-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“finished client unary call” ctx_id=9a1bb64f-b8f8-4b4c-84fd-fc33022896eb grpc.code=OK grpc.ctx_id=d751047f-ba0b-4697-89c4-69e0d91282ab grpc.duration=69.586199ms grpc.method=HandleUplinkData grpc.service=as.ApplicationServerService span.kind=client system=grpc
chirpstack-application-server_1 | time=“2020-06-08T14:58:53Z” level=info msg="downlink device-queue item acknowledged"dev_eui=2c1361db209ac960
chirpstack-network-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“device-queue deleted” ctx_id=9a1bb64f-b8f8-4b4c-84fd-fc33022896eb id=9
chirpstack-network-server_1 | time=“2020-06-08T14:58:53Z” level=warning msg=“device-queue item discarded due to timeout” ctx_id=9a1bb64f-b8f8-4b4c-84fd-fc33022896eb dev_eui=2c1361db209ac960 device_queue_item_fcnt=29
chirpstack-application-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“finished unary call with code OK” ctx_id=7ef3353a-5092-4b52-93a7-b034197e9d75 grpc.code=OK grpc.method=HandleDownlinkACK grpc.service=as.ApplicationServerService grpc.start_time=“2020-06-08T14:58:53Z” grpc.time_ms=10.209 peer.address=“172.20.0.3:33320” span.kind=server system=grpc
chirpstack-application-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“integration/mqtt: publishing message” ctx_id=7ef3353a-5092-4b52-93a7-b034197e9d75 qos=0 topic=application/1/device/2c1361db209ac960/ack
chirpstack-network-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“finished client unary call” ctx_id=9a1bb64f-b8f8-4b4c-84fd-fc33022896eb grpc.code=OK grpc.ctx_id=7ef3353a-5092-4b52-93a7-b034197e9d75 grpc.duration=12.165429ms grpc.method=HandleDownlinkACK grpc.service=as.ApplicationServerService span.kind=client system=grpc
chirpstack-gateway-bridge_1 | time=“2020-06-08T14:58:53Z” level=info msg=“integration/mqtt: downlink frame received” downlink_id=9a1bb64f-b8f8-4b4c-84fd-fc33022896eb gateway_id=b827ebfffe0cf2da
chirpstack-network-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“adr request added to mac-command queue” ctx_id=9a1bb64f-b8f8-4b4c-84fd-fc33022896eb dev_eui=2c1361db209ac960 dr=2 nb_trans=1 req_dr=8 req_nb_trans=1 req_tx_power_idx=0 tx_power=0
chirpstack-network-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“pending mac-command block set” cid=LinkADRReq commands=2 ctx_id=9a1bb64f-b8f8-4b4c-84fd-fc33022896eb dev_eui=2c1361db209ac960
chirpstack-network-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“pending mac-command block set” cid=RXParamSetupReq commands=1 ctx_id=9a1bb64f-b8f8-4b4c-84fd-fc33022896eb dev_eui=2c1361db209ac960
chirpstack-network-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“gateway/mqtt: publishing gateway command” command=down downlink_id=9a1bb64f-b8f8-4b4c-84fd-fc33022896eb gateway_id=b827ebfffe0cf2da qos=0 topic=gateway/b827ebfffe0cf2da/command/down
chirpstack-network-server_1 | time=“2020-06-08T14:58:53Z” level=info msg=“downlink-frames saved” ctx_id=9a1bb64f-b8f8-4b4c-84fd-fc33022896eb token=39451
chirpstack-gateway-bridge_1 | time=“2020-06-08T14:59:00Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 stats_id=b48f695e-dd94-4813-a2cc-d2db4267ff8b topic=gateway/b827ebfffe0cf2da/event/stats
chirpstack-network-server_1 | time=“2020-06-08T14:59:00Z” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=b827ebfffe0cf2da stats_id=b48f695e-dd94-4813-a2cc-d2db4267ff8b
chirpstack-network-server_1 | time=“2020-06-08T14:59:00Z” level=info msg=“gateway updated” ctx_id=b48f695e-dd94-4813-a2cc-d2db4267ff8b gateway_id=b827ebfffe0cf2da
chirpstack-application-server_1 | time=“2020-06-08T14:59:00Z” level=info msg=“gateway updated” ctx_id=898f457f-e982-4367-8968-3f657f79d929 id=b827ebfffe0cf2da name=Rak831_Gateway
chirpstack-network-server_1 | time=“2020-06-08T14:59:00Z” level=info msg=“finished client unary call” ctx_id=b48f695e-dd94-4813-a2cc-d2db4267ff8b grpc.code=OK grpc.ctx_id=898f457f-e982-4367-8968-3f657f79d929 grpc.duration=41.12343ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
chirpstack-application-server_1 | time=“2020-06-08T14:59:00Z” level=info msg=“metrics saved” aggregation="[MINUTE HOURDAY MONTH]" ctx_id=898f457f-e982-4367-8968-3f657f79d929 name=“gw:b827ebfffe0cf2da”
chirpstack-application-server_1 | time=“2020-06-08T14:59:00Z” level=info msg=“finished unary call with code OK” ctx_id=898f457f-e982-4367-8968-3f657f79d929 grpc.code=OK grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService grpc.start_time=“2020-06-08T14:59:00Z” grpc.time_ms=40.274 peer.address=“172.20.0.3:33320” span.kind=server system=grp
