Not sure if this is for GatewayBridge.
I have first time experience with chirpstack and I managed to setup system on RAK gateway.
I use default settings in packet forwarder, gatewa bridge and network server with slight change if IP to use my local Mosquitto broker. Sensor packet are transfered through this chain from sensor to network server. But on Mosquitto side I can’t / don’t know how to see sensor data. I see event/ack, stats, up ; command/down, but cant find sensor data.
In the same time in Chirpstack Network server in Applications/app/Devices/Device/Device Data I can see live sensor data.
When broker is stopped NetworkServer is not able to receive data.
On the other hand I have my client subscribed to following topics
“/gateway/+/event/+”
“gateway/Gateway_Id/event/stats”
“gateway/Gateway_Id/event/+”
“gateway/Gateway_Id/event/up”
with bridge [integration.mqtt] topics configuration
[ Event topic template.]
event_topic_template=“gateway/{{ .GatewayID }}/event/{{ .EventType }}”
[ Command topic template]
command_topic_template=“gateway/{{ .GatewayID }}/command/#”
Any hint, help will be more then wellcome
Regards
