Everything is reporting ok for the servics. I’m not sure how to check the other settings, is there something you can suggest?
Here’s the log file for messages.
Aug 8 15:57:54 raspberrypi3 user.info chirpstack-gateway-bridge[747]: time=“2020-08-08T15:57:54Z” level=info msg=“backend/concentratord: stats event received” stats_id=f2633b1d-942c-4b51-a4fa-2cd71d385c79
Aug 8 15:57:54 raspberrypi3 user.info chirpstack-gateway-bridge[747]: time=“2020-08-08T15:57:54Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 stats_id=f2633b1d-942c-4b51-a4fa-2cd71d385c79 topic=gateway/b827ebfffe9046fd/event/stats
Aug 8 15:57:54 raspberrypi3 user.info chirpstack-network-server[366]: time=“2020-08-08T15:57:54Z” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=b827ebfffe9046fd stats_id=f2633b1d-942c-4b51-a4fa-2cd71d385c79
Aug 8 15:57:54 raspberrypi3 user.warn chirpstack-network-server[366]: time=“2020-08-08T15:57:54Z” level=warning msg=“gateway/stats: stats received by unknown gateway” ctx_id=f2633b1d-942c-4b51-a4fa-2cd71d385c79 gateway_id=b827ebfffe9046fd
Aug 08 15:57:55 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902275.289960688s
Aug 08 15:57:56 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902276.290323633s
Aug 08 15:57:57 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902277.290698765s
Aug 08 15:57:58 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902278.290903637s
Aug 08 15:57:59 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902279.291097934s
Aug 08 15:58:00 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902280.291293377s
Aug 08 15:58:01 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902281.291666111s
Aug 08 15:58:02 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902282.292035094s
Aug 08 15:58:03 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902283.292442097s
Aug 08 15:58:04 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902284.292814569s
Aug 08 15:58:05 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902285.293186727s
Aug 08 15:58:06 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902286.293557219s
Aug 08 15:58:07 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902287.293763803s
Aug 08 15:58:08 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902288.293970231s
Aug 08 15:58:09 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902289.294177283s
Aug 08 15:58:10 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902290.294385741s
Aug 08 15:58:11 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902291.294594459s
Aug 08 15:58:12 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902292.294802603s
Aug 08 15:58:13 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902293.295013872s
Aug 08 15:58:14 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902294.295220973s
Aug 08 15:58:15 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902295.295411824s
Aug 08 15:58:16 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902296.295602049s
Aug 08 15:58:17 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902297.295796597s
Aug 08 15:58:18 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902298.295990831s
Aug 08 15:58:19 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902299.296355169s
Aug 08 15:58:20 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902300.2967206s
Aug 08 15:58:21 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902301.297093166s
Aug 08 15:58:22 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902302.297305784s
Aug 08 15:58:23 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902303.297521786s
Aug 08 15:58:24 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902304.29774534s
Aug 08 15:58:24 raspberrypi3 user.info chirpstack-concentratord-sx1301[508]: Publishing stats event, stats_id: 10803e3e-fbd0-4f84-82bb-0cd2fdbac1fb, rx_received: 0, rx_received_ok: 0, tx_received: 0, tx_emitted: 0
Aug 8 15:58:24 raspberrypi3 user.info chirpstack-gateway-bridge[747]: time=“2020-08-08T15:58:24Z” level=info msg=“backend/concentratord: stats event received” stats_id=10803e3e-fbd0-4f84-82bb-0cd2fdbac1fb
Aug 8 15:58:24 raspberrypi3 user.info chirpstack-gateway-bridge[747]: time=“2020-08-08T15:58:24Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 stats_id=10803e3e-fbd0-4f84-82bb-0cd2fdbac1fb topic=gateway/b827ebfffe9046fd/event/stats
Aug 8 15:58:24 raspberrypi3 user.info chirpstack-network-server[366]: time=“2020-08-08T15:58:24Z” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=b827ebfffe9046fd stats_id=10803e3e-fbd0-4f84-82bb-0cd2fdbac1fb
Aug 8 15:58:24 raspberrypi3 user.warn chirpstack-network-server[366]: time=“2020-08-08T15:58:24Z” level=warning msg=“gateway/stats: stats received by unknown gateway” ctx_id=10803e3e-fbd0-4f84-82bb-0cd2fdbac1fb gateway_id=b827ebfffe9046fd
Aug 08 15:58:25 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902305.297975404s
Aug 08 15:58:26 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902306.298199113s
Aug 08 15:58:27 raspberrypi3 user.warn chirpstack-concentratord-sx1301[508]: GPS time reference is not valid, age: 1596902307.298402301s
Here’s log file for boot:
raspberrypi3:/var/log$ sudo head -n 200 boot
Sun Aug 2 15:01:35 2020: Sun Aug 2 15:01:35 UTC 2020
Sun Aug 2 15:01:35 2020: INIT: Entering runlevel: 5
Sun Aug 2 15:01:35 2020: Configuring network interfaces… done.
Sun Aug 2 15:01:35 2020: Starting system message bus: dbus.
Sun Aug 2 15:01:35 2020: Starting random number generator daemon.
Sun Aug 2 15:01:35 2020: Starting Connection Manager
Sun Aug 2 15:01:36 2020: Starting Dropbear SSH server: dropbear.
Sun Aug 2 15:01:36 2020: Starting rpcbind daemon…done.
Sun Aug 2 15:01:36 2020: Starting advanced power management daemon: No APM support in kernel
Sun Aug 2 15:01:36 2020: (failed.)
Sun Aug 2 15:01:36 2020: Starting bluetooth: bluetoothd.
Sun Aug 2 15:01:36 2020: Starting chirpstack-application-server
Sun Aug 2 15:01:36 2020: Starting chirpstack-concentratord
Sun Aug 2 15:01:36 2020: Starting chirpstack-gateway-bridge
Sun Aug 2 15:01:36 2020: Starting chirpstack-network-server
Sun Aug 2 15:01:36 2020: Starting ntpd: done
Sun Aug 2 15:01:37 2020: Starting postgresql-server service: [ OK ]
Sat Aug 8 15:01:49 2020: Starting syslogd/klogd: done
Sat Aug 8 15:01:49 2020: wireguard is disabled, update /etc/default/wireguard
Sat Aug 8 15:01:49 2020: * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
Sat Aug 8 15:01:49 2020: …done.
Sat Aug 8 15:01:49 2020: Starting Telephony daemon
Sat Aug 8 15:01:49 2020: Starting Mosquitto message broker mosquitto
Sat Aug 8 15:01:49 2020: Starting swupdate …
Sat Aug 8 15:01:49 2020: Starting redis-server…
Sat Aug 8 15:01:49 2020: Cleaning up Redis append-only file
Sat Aug 8 15:01:49 2020: Swupdate v2020.04.0
Sat Aug 8 15:01:49 2020: Licensed under GPLv2. See source distribution for detailed copyright notices.
Sat Aug 8 15:01:49 2020: Registered handlers:
Sat Aug 8 15:01:49 2020: dummy
Sat Aug 8 15:01:49 2020: uboot
Sat Aug 8 15:01:49 2020: bootloader
Sat Aug 8 15:01:49 2020: lua
Sat Aug 8 15:01:49 2020: raw
Sat Aug 8 15:01:49 2020: rawfile
Sat Aug 8 15:01:49 2020: rawcopy
Sat Aug 8 15:01:49 2020: shellscript
Sat Aug 8 15:01:49 2020: preinstall
Sat Aug 8 15:01:49 2020: postinstall
Sat Aug 8 15:01:49 2020: [TRACE] : SWUPDATE running : [network_initializer] : Main loop Daemon
Sat Aug 8 15:01:49 2020: [TRACE] : SWUPDATE running : [listener_create] : creating socket at /tmp/sockinstctrl
Sat Aug 8 15:01:49 2020: [TRACE] : SWUPDATE running : [listener_create] : creating socket at /tmp/swupdateprog
Sat Aug 8 15:01:49 2020: Connected to SWUpdate via /tmp/swupdateprog
Sat Aug 8 15:01:50 2020: AOF analyzed: size=4509459, ok_up_to=4509459, diff=0
Sat Aug 8 15:01:50 2020: AOF is valid
Sat Aug 8 15:01:50 2020: 466:C 08 Aug 2020 15:01:50.598 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
Sat Aug 8 15:01:50 2020: 466:C 08 Aug 2020 15:01:50.603 # Redis version=5.0.9, bits=32, commit=00000000, modified=0, pid=466, just started
Sat Aug 8 15:01:50 2020: 466:C 08 Aug 2020 15:01:50.603 # Configuration loaded
Sat Aug 8 15:01:50 2020: Starting MonitStarting Monit 5.26.0 daemon with http interface at [localhost]:2812
Sat Aug 8 15:01:50 2020: .
