NS or AS config wrong, lead to chirpstack simulator runs wrong
This is my application server config file, and 10.0.0.76 is my network server address, which is on the different machine of this application server.
  # Settings for the "internal api"
  # This is the API used by ChirpStack Network Server to communicate with ChirpStack Application Server
  # and should not be exposed to the end-user.
  [application_server.api]
  bind="0.0.0.0:8001"
  # ca certificate used by the api server (optional)
  ca_cert=""
  # tls certificate used by the api server (optional)
  tls_cert=""
  # tls key used by the api server (optional)
  tls_key=""
  # Public ip:port of the application-server API.
  # This is used by ChirpStack Network Server to connect to ChirpStack Application Server. When running
  # ChirpStack Application Server on a different host than ChirpStack Network Server, make sure to set
  # this to the host:ip on which ChirpStack Network Server can reach ChirpStack Application Server.
  # The port must be equal to the port configured by the 'bind' flag
  # above.
  public_host="10.0.0.76:8001"
After I make this configuration, I use the simulator to do the simulation, but I got this error from my network server:
Jul 20 03:34:30 iot chirpstack-network-server[13495]: time="2020-07-20T03:34:30Z" level=info msg="uplink: frame(s) collected" ctx_id=0b6dad19-7929-4bed-bb67-9008b486556b mtype=UnconfirmedDataUp uplink_ids="[6cb4a83c-f570-4904-b446-0624991f61f4 dbc6074f-650a-4df8-9576-6146a36a5b1c 968d90b6-01a9-4e1d-be38-90543db9b7fe 5baac7aa-153a-4fae-a529-fd0cd9b2aef5 946ccc13-0319-4213-9b91-e1c0c49951f1 afdbb362-97a2-4249-9719-48aa1450defa 772d7f19-4d56-4d22-becb-ccaea356dcc2 a7738da4-83f5-4365-a6b0-3cf772c9b7e0 a38e2897-e83d-4ad9-8b93-a74bde9ced1e 28db8d23-e504-4226-ab1f-943d1cfbaf18 2b67b2bf-d52a-469c-a9bf-634041f3e7c0 da6659a9-84a4-4257-8132-7cd76534074f 157f0901-9028-4d04-8f93-563f5616ebf8 4ec38966-99a4-402c-a86b-273aa597928f 813d3844-70a2-47d5-aafc-20034d14ba31 0db5dfaa-695e-4372-9b59-7cc4f1060d18 e689ac10-d967-4c50-bf78-7e32b7815805 f49573fb-7dfa-42e1-ba9e-6f54e885ce95 566c0318-9f01-461e-a14d-8fa440dc2a5b 19a22aa0-7ca3-4c8b-8d58-581a9a8c3f85]"
Jul 20 03:34:30 iot chirpstack-network-server[13495]: time="2020-07-20T03:34:30Z" level=warning msg="creating insecure application-server client" server="localhost:8001"
Jul 20 03:34:30 iot chirpstack-network-server[13495]: time="2020-07-20T03:34:30Z" level=warning msg="grpc: addrConn.createTransport failed to connect to {127.0.0.1:8001  <nil> 0 <nil>}. Err: connection error: desc = \"transport: Error while dialing dial tcp 127.0.0.1:8001: connect: connection refused\". Reconnecting..."
Jul 20 03:34:31 iot chirpstack-network-server[13495]: time="2020-07-20T03:34:31Z" level=error msg="uplink: processing uplink frame error" ctx_id=0b6dad19-7929-4bed-bb67-9008b486556b error="get application-server client error: create application-server api client error: dial application-server api error: context deadline exceeded"
May I ask what I did wrong? From the log, I see it keep connect 127.0.0.1:8001, but I think I already change to network_server_ip:8001 in the config file.
I install the components on sperate machine
I do this is because I want to test the topline of the lora network support, I want to build a AWS-cloud lora network, but I see the AWS’s plan counts by CPU, RAM, bandwidth usage. So I want to do a simulation to see how to calculate the [ n sensors + 1 gateway + 1 NS + AS ] hardware requirement, for example n=500, the palyload data is 14Bytes (BME280), then NS need 1 cpu 1 GB RAM, and AS need 2 cpu 2 GB RAM, etc. So I can purchase that plan, and I will use the auto-scalling, so after the network is scalling, then it will generate more instance of NS and AS with same hardware setup.
Below is my full ns.toml and as.toml
[general]
# Log level
log_level=4
# Log to syslog.
# When set to true, log messages are being written to syslog.
log_to_syslog=false
# PostgreSQL settings.
# Please note that PostgreSQL 9.5+ is required.
[postgresql]
# PostgreSQL dsn (e.g.: postgres://user:password@hostname/database?sslmode=disable).
# Besides using an URL (e.g. 'postgres://user:password@hostname/database?sslmode=disable')
# it is also possible to use the following format:
# 'user=chirpstack_ns dbname=chirpstack_ns sslmode=disable'.
# The following connection parameters are supported:
# * dbname - The name of the database to connect to
# * user - The user to sign in as
# * password - The user's password
# * host - The host to connect to. Values that start with / are for unix domain sockets. (default is localhost)
# * port - The port to bind to. (default is 5432)
# * sslmode - Whether or not to use SSL (default is require, this is not the default for libpq)
# * fallback_application_name - An application_name to fall back to if one isn't provided.
# * connect_timeout - Maximum wait for connection, in seconds. Zero or not specified means wait indefinitely.
# * sslcert - Cert file location. The file must contain PEM encoded data.
# * sslkey - Key file location. The file must contain PEM encoded data.
# * sslrootcert - The location of the root certificate file. The file must contain PEM encoded data.
# Valid values for sslmode are:
# * disable - No SSL
dsn="postgres://chirpstack_ns:dbpassword@10.0.0.78/chirpstack_ns?sslmode=disable"
# Automatically apply database migrations.
# It is possible to apply the database-migrations by hand
# (see https://github.com/brocaar/chirpstack-network-server/tree/master/migrations)
# or let ChirpStack Application Server migrate to the latest state automatically, by using
# this setting. Make sure that you always make a backup when upgrading ChirpStack
# Application Server and / or applying migrations.
automigrate=true
# Max open connections.
# PostgreSQL connection pool (0 = unlimited).
max_open_connections=0
# Max idle connections.
# This sets the max. number of idle connections in the PostgreSQL connection
# pool (0 = no idle connections are retained).
max_idle_connections=2
# Redis settings
# Please note that Redis 2.6.0+ is required.
[redis]
# Redis url (e.g. redis://user:password@hostname/0)
# For more information about the Redis URL format, see:
# https://www.iana.org/assignments/uri-schemes/prov/redis
url="redis://10.0.0.79:6379"
# Redis Cluster.
# Set this to true when the provided URL is pointing to a Redis Cluster
# instance.
cluster=false
# The master name.
# Set the master name when the provided URL is pointing to a Redis Sentinel
# instance.
master_name=""
# Connection pool size.
# Default is 10 connections per every CPU.
pool_size=0
# Network-server settings.
[network_server]
# Network identifier (NetID, 3 bytes) encoded as HEX (e.g. 010203)
net_id="000000"
# Time to wait for uplink de-duplication.
# This is the time that ChirpStack Network Server will wait for other gateways to receive
# the same uplink frame. Valid units are 'ms' or 's'.
# Please note that this value has influence on the uplink / downlink
# roundtrip time. Setting this value too high means ChirpStack Network Server will be
# unable to respond to the device within its receive-window.
deduplication_delay="200ms"
# Device session expiration.
# The TTL value defines the time after which a device-session expires
# after no activity. Valid units are 'ms', 's', 'm', 'h'. Note that these
# values can be combined, e.g. '24h30m15s'.
device_session_ttl="744h0m0s"
# Get downlink data delay.
# This is the time that ChirpStack Network Server waits between forwarding data to the
# application-server and reading data from the queue. A higher value
# means that the application-server has more time to schedule a downlink
# queue item which can be processed within the same uplink / downlink
# transaction.
get_downlink_data_delay="100ms"
  # LoRaWAN regional band configuration.
  # Note that you might want to consult the LoRaWAN Regional Parameters
  # specification for valid values that apply to your region.
  # See: https://www.lora-alliance.org/lorawan-for-developers
  [network_server.band]
  # LoRaWAN band to use.
  # Valid values are:
  # * AS923
  # * AU915
  # * CN470
  # * CN779
  # * EU433
  # * EU868
  # * IN865
  # * KR920
  # * RU864
  # * US915
  name="AS923"
  # Enforce 400ms dwell time.
  # Some regions require the configuration of the dwell time, which will
  # limit the time-on-air to 400ms. Please refer to the LoRaWAN Regional
  # Parameters specification for more information.
  # When configured and required in the configured region, ChirpStack Network Server will
  # use the TxParamSetup mac-command to communicate this to the devices.
  uplink_dwell_time_400ms=false
  downlink_dwell_time_400ms=false
  # Uplink max. EIRP.
  # This defines the maximum allowed device EIRP which must be configured
  # for some regions. Please refer the LoRaWAN Regional Parameters specification
  # for more information. Set this to -1 to use the default value for this
  # region.
  # When required in the configured region, ChirpStack Network Server will use the
  # TxParamSetup mac-command to communicate this to the devices.
  # For regions where the TxParamSetup mac-command is not implemented, this
  # setting is ignored.
  uplink_max_eirp=-1
  # Enforce repeater compatibility.
  # Most band configurations define the max payload size for both an optional
  # repeater encapsulation layer as for setups where a repeater will never
  # be used. The latter case increases the max payload size for some data-rates.
  # In case a repeater might used, set this flag to true.
  repeater_compatible=false
  # LoRaWAN network related settings.
  # surrounded gateways.
  installation_margin=10
  # RX window (Class-A).
  # Set this to:
  # 0: RX1 / RX2
  # 1: RX1 only
  # 2: RX2 only
  rx_window=0
  # Class A RX1 delay
  # 0=1sec, 1=1sec, ... 15=15sec. A higher value means ChirpStack Network Server has more
  # time to respond to the device as the delay between the uplink and the
  # first receive-window will be increased.
  rx1_delay=1
  # RX1 data-rate offset
  # Please consult the LoRaWAN Regional Parameters specification for valid
  # options of the configured network_server.band.name.
  rx1_dr_offset=0
  # RX2 data-rate
  # When set to -1, the default RX2 data-rate will be used for the configured
  # LoRaWAN band.
  rx2_dr=-1
  # RX2 frequency
  # When set to -1, the default RX2 frequency will be used.
  rx2_frequency=-1
  rx2_prefer_on_rx1_dr_lt=0
  # Prefer RX2 on link budget.
  # Prefer gateways for downlink with given uplink (SNR) margin.
  # When receiving an uplink (by multiple gateways), the Network Server will
  # prefer the gateways that have at least the configured margin for the uplink
  # SNR when sending a downlink. Margin:
  #   uplink SNR - required SNR for spreading factor
  #  * In case multiple gateways match, the Network Server will select a random
  #    gateway from the match.
  #  * In case non of the gateways have the desired margin or the uplink
  #    modulation was not LoRa, then the gateway with the best SNR (or RSSI
  #    in case of FSK) will be selected when sending a downlink.
  gateway_prefer_min_margin=10
  # Downlink TX Power (dBm)
  # be used.
  downlink_tx_power=-1
  # Disable mac-commands
  # When set to true, ChirpStack Network Server will not handle and / or schedule any
  # mac-commands. However, it is still possible for an external controller
  # to handle and / or schedule mac-commands. This is intended for testing
  # only.
  disable_mac_commands=false
  # Disable ADR
  # When set, this globally disables ADR.
  disable_adr=false
  # Max mac-command error count.
  # When a mac-command is nACKed for more than the configured value, then the
  # ChirpStack Network Server will stop sending this mac-command to the device.
  # This setting prevents that the Network Server will keep sending mac-commands
  # on every downlink in case of a malfunctioning device.
  max_mac_command_error_count=3
  # Enable only a given sub-set of channels
  # Use this when ony a sub-set of the by default enabled channels are being
  # used. For example when only using the first 8 channels of the US band.
  # Note: when left blank, all channels will be enabled.
  # For the US band, there are 64 125kHz channels (0-63) with 8 500kHz
  # channels (65-71) with frequencies in the middle of each
  # sub-band of 125kHz channels.
  # Most US LoRa gateways recieve on only one sub-band which consists of
  # 8 125kHz channels and 1 500 kHz channel
  # Example: (sub-band 1)
  # enabled_uplink_channels=[0, 1, 2, 3, 4, 5, 6, 7, 64]
  # Exmaple: (sub-band 2)
  # enabled_uplink_channels=[8, 9, 10, 11, 12, 13, 14, 15, 65]
  enabled_uplink_channels=[]
  # Extra channel configuration.
  # Use this for LoRaWAN regions where it is possible to extend the by default
  # available channels with additional channels (e.g. the EU band).
  # The first 5 channels will be configured as part of the OTAA join-response
  # (using the CFList field).
  # The other channels (or channel / data-rate changes) will be (re)configured
  # using the NewChannelReq mac-command.
  # Example:
  # [[network_server.network_settings.extra_channels]]
  # frequency=867100000
  # min_dr=0
  # max_dr=5
  # frequency=867300000
  # min_dr=0
  # max_dr=5
  # frequency=867500000
  # min_dr=0
  # max_dr=5
  # frequency=867700000
  # min_dr=0
  # max_dr=5
  # frequency=867900000
  # min_dr=0
  # max_dr=5
  # Class B settings
  [network_server.network_settings.class_b]
  # Ping-slot data-rate.
  ping_slot_dr=0
  # Ping-slot frequency (Hz)
  # Set this to 0 to use the default frequency plan for the configured region
  ping_slot_frequency=0
  # Rejoin-request settings
  # When enabled, ChirpStack Network Server will request the device to send a rejoin-request
  # every time when one of the 2 conditions below is met (frame count or time).
  [network_server.network_settings.rejoin_request]
  # Request device to periodically send rejoin-requests
  enabled=false
  # The device must send a rejoin-request type 0 at least every 2^(max_count_n + 4)
  # uplink messages. Valid values are 0 to 15.
  max_count_n=0
  # The device must send a rejoin-request type 0 at least every 2^(max_time_n + 10)
  # seconds. Valid values are 0 to 15.
  # 0  = roughly 17 minutes
  # 15 = about 1 year
  max_time_n=0
  # Scheduler settings
  # These settings affect the multicast, Class-B and Class-C downlink queue
  # scheduler.
  [network_server.scheduler]
  # Scheduler interval
  # The interval in which the downlink scheduler for multicast, Class-B and
  # Class-C runs.
  scheduler_interval="1s"
    # Class-C settings.
    [network_server.scheduler.class_c]
    # Downlink lock duration
    # Contains the duration to lock the downlink Class-C transmissions
    # after a preceeding downlink tx (per device).
    downlink_lock_duration="2s"
        # Multicast gateway delay.
        # In case of a multi-gateway multicast downlink, this delay will added to
        # the transmission time of each downlink to avoid collisions between overlapping
        # gateways.
        multicast_gateway_delay="2s"
  # Network-server API
  # This is the network-server API that is used by ChirpStack Application Server or other
  # custom components interacting with ChirpStack Network Server.
  [network_server.api]
  bind="0.0.0.0:8000"
  ca_cert=""
  tls_cert=""
  tls_key=""
  # Backend defines the gateway backend settings.
  # The gateway backend handles the communication with the gateway(s) part of
  # the LoRaWAN network.
  [network_server.gateway.backend]
    # Backend
    # This defines the backend to use for the communication with the gateways.
    # Use the section name of one of the following gateway backends.
    # Valid options are:
    #  * mqtt
    #  * amqp
    #  * gcp_pub_sub
    #  * azure_iot_hub
    type="mqtt"
    # MQTT gateway backend settings.
    # This is the backend communicating with the LoRa gateways over a MQTT broker.
    # MQTT topic templates for the different MQTT topics.
    # The meaning of these topics are documented at:
    # https://www.chirpstack.io/gateway-bridge/
    # The default values match the default expected configuration of the
    # ChirpStack Gateway Bridge MQTT backend. Therefore only change these values when
    # absolutely needed.
    # Event topic template.
    event_topic="gateway/+/event/+"
    # Command topic template.
    # Use:
    #   * "{{ .GatewayID }}" as an substitution for the LoRa gateway ID
    #   * "{{ .CommandType }}" as an substitution for the command type
    command_topic_template="gateway/{{ .GatewayID }}/command/{{ .CommandType }}"
    server="tcp://10.0.0.77:1883"
    username="user"
    password="sengital"
    # Maximum interval that will be waited between reconnection attempts when connection is lost.
    # Valid units are 'ms', 's', 'm', 'h'. Note that these values can be combined, e.g. '24h30m15s'.
    max_reconnect_interval="1m0s"
    # Quality of service level
    # 0: at most once
    # 1: at least once
    # 2: exactly once
    qos=0
    # Clean session
    clean_session=true
    # Client ID
    client_id=""
    ca_cert=""
    tls_cert=""
    # TLS key file (optional)
    tls_key=""
    # AMQP / RabbitMQ.
    # Use this backend when the ChirpStack Gateway Bridge is configured to connect
    # to RabbitMQ using the MQTT plugin. See for more details about this plugin:
    # https://www.rabbitmq.com/mqtt.html
    [network_server.gateway.backend.amqp]
    # Server URL.
    # See for a specification of all the possible options:
    # https://www.rabbitmq.com/uri-spec.html
    url="amqp://guest:guest@localhost:5672"
    # Event queue name.
    # This queue will be created when it does not yet exist and is used to
    # queue the events received from the gateway.
    event_queue_name="gateway-events"
    # Event routing key.
    # This is the routing-key used for creating the queue binding.
    event_routing_key="gateway.*.event.*"
    # Command routing key template.
    # This is the command routing-key template used when publishing gateway
    # commands.
    command_routing_key_template="gateway.{{ .GatewayID }}.command.{{ .CommandType }}"
    # Google Cloud Pub/Sub backend.
    # to the Google Cloud IoT Core MQTT broker (which integrates with Pub/Sub).
    [network_server.gateway.backend.gcp_pub_sub]
    # Path to the IAM service-account credentials file.
    # Note: this service-account must have the following Pub/Sub roles:
    #  * Pub/Sub Editor
    credentials_file=""
    # Google Cloud project id.
    project_id=""
    # Uplink Pub/Sub topic name (to which Cloud IoT Core publishes).
    uplink_topic_name=""
    # Downlink Pub/Sub topic name (for publishing downlink frames).
    downlink_topic_name=""
    # Uplink retention duration.
    # The retention duration that ChirpStack Network Server will set on the uplink subscription.
    uplink_retention_duration="24h0m0s"
    # Azure IoT Hub backend.
    # to the Azure IoT Hub MQTT broker.
    [network_server.gateway.backend.azure_iot_hub]
    # Events connection string.
    # This connection string must point to the Service Bus Queue to which the
    # IoT Hub is forwarding the (uplink) gateway events.
    events_connection_string=""
    # Commands connection string.
    # This connection string must point to the IoT Hub and is used by ChirpStack Network Server
    # for sending commands to the gateways.
    commands_connection_string=""
  # Geolocation settings.
  # When set, ChirpStack Network Server will use the configured geolocation server to
  # resolve the location of the devices.
  [geolocation_server]
  # Server.
  # The hostname:ip of the geolocation service (optional).
  server=""
  # CA certificate used by the API client (optional).
  ca_cert=""
  # TLS certificate used by the API client (optional).
  tls_cert=""
  # TLS key used by the API client (optional).
  tls_key=""
  # Monitoring settings.
  # Note that this replaces the metrics configuration. If a metrics section is
  # found in the configuration, then it will fall back to that and the monitoring
  # section is ignored.
  [monitoring]
  # IP:port to bind the monitoring endpoint to.
  # When left blank, the monitoring endpoint will be disabled.
  bind=""
  # Prometheus metrics endpoint.
  # When set true, Prometheus metrics will be served at '/metrics'.
  prometheus_endpoint=false
  # Prometheus API timing histogram.
  # By setting this to true, the API request timing histogram will be enabled.
  # See also: https://github.com/grpc-ecosystem/go-grpc-prometheus#histograms
  prometheus_api_timing_histogram=false
  # Health check endpoint.
  # When set to true, the healthcheck endpoint will be served at '/health'.
  # When requesting, this endpoint will perform the following actions to
  # determine the health of this service:
  #   * Ping PostgreSQL database
  #   * Ping Redis database
  healthcheck_endpoint=false
# Join-server settings.
[join_server]
# Resolve JoinEUI (experimental).
# Default join-server settings.
# When set to true, ChirpStack Network Server will use the JoinEUI to resolve the join-server
# for the given JoinEUI. ChirpStack Network Server will fallback on the default join-server
# when resolving the JoinEUI fails.
resolve_join_eui=false
# Resolve domain suffix.
# This configures the domain suffix used for resolving the join-server.
resolve_domain_suffix="10.0.0.80"
  # Join-server certificates.
  # Example:
  # [[join_server.certificates]]
  # # JoinEUI.
  # # The JoinEUI of the joinserver to to use the certificates for.
  # join_eui="0102030405060708"
  # # CA certificate (optional).
  # # Set this to validate the join-server server certificate (e.g. when the
  # # certificate was self-signed).
  # ca_cert="/path/to/ca.pem"
  # # TLS client-certificate (optional).
  # # Set this to enable client-certificate authentication with the join-server.
  # tls_cert="/path/to/tls_cert.pem"
  # # TLS client-certificate key (optional).
  # tls_key="/path/to/tls_key.pem"
  # This join-server will be used when resolving the JoinEUI is set to false
  # or as a fallback when resolving the JoinEUI fails.
  [join_server.default]
  # hostname:port of the default join-server
  # This API is provided by ChirpStack Application Server.
  server="http://10.0.0.80:8003"
  # ca certificate used by the default join-server client (optional)
  ca_cert=""
  # tls certificate used by the default join-server client (optional)
  tls_cert=""
  # tls key used by the default join-server client (optional)
  tls_key=""
  # Join-server KEK set.
  # These KEKs (Key Encryption Keys) are used to decrypt the network related
  # session-keys received from the join-server on a (re)join-accept.
  # Please refer to the LoRaWAN Backend Interface specification
  # 'Key Transport Security' section for more information.
  # Example (the [[join_server.kek.set]] can be repeated):
  # [[join_server.kek.set]]
  # # KEK label.
  # label="000000"
  # # Key Encryption Key.
  # kek="01020304050607080102030405060708"
  # Network-controller configuration.
  [network_controller]
  # hostname:port of the network-controller api server (optional)
  server=""
  # ca certificate used by the network-controller client (optional)
  ca_cert=""
  # tls certificate used by the network-controller client (optional)
  tls_cert=""
  # tls key used by the network-controller client (optional)
  tls_key=""
