Hello guys!!! I enabled the integration in the application server to save the events in a database in aws. I saved the events correctly but verified that they are not saved in order by received_at.
Follow the recommended structure:
create table device_up (
id uuid primary key,
received_at timestamp with time zone not null,
dev_eui bytea not null,
device_name varchar(100) not null,
application_id bigint not null,
application_name varchar(100) not null,
frequency bigint not null,
dr smallint not null,
adr boolean not null,
f_cnt bigint not null,
f_port smallint not null,
data bytea not null,
rx_info jsonb not null,
object jsonb not null
-- NOTE: These are recommended indices, depending on how this table is being
-- used, you might want to change these.
create index idx_device_up_received_at on device_up(received_at);
create index idx_device_up_dev_eui on device_up(dev_eui);
create index idx_device_up_application_id on device_up(application_id);
create index idx_device_up_frequency on device_up(frequency);
create index idx_device_up_dr on device_up(dr);
Is there any way to save the data in an organized way by received_at without
having to use the postgres command "SELECT * FROM device_up ORDER BY received_at ASC" ?
