Apparently the certs are correct, but chirp is reporting tls error during handshake.
Is there anyway this can be tested by someone that knows more about this?
I tried mapping the letsencrypt certs, but it also still throws the same error. what are the names of the letsencrypt certs you are mapping so i can double check i’m mapping the right ones.
Either way i cant seem to get past this error no matter what certs i used at the moment and making the logs show debug doesnt give me any futher verbosity on the issue.
2023-11-08T00:43:29.743971Z INFO up{deduplication_id=7750ba1d-5146-435e-a2af-5c782f116d5a}:data_up:data_pr: chirpstack::uplink::data_fns: Starting passive-roaming session net_id=000013 dev_addr=260d8135
2023-11-08T00:43:59.838479Z ERROR up{deduplication_id=7750ba1d-5146-435e-a2af-5c782f116d5a}:data_up:data_pr: chirpstack::uplink::data_fns: Start passive-roaming error net_id=000013 error=channel closed
this was my last correspondence with ttn. so i really have no idea how to further debug this. if anyone has any idea please lmk.
The certs look good now, but curl still fails and Packet Broker shows:
roaming: request failed: Post \"https://example.com:5138\": remote error: tls: handshake failure
"remote error" indicates that the server (ChirpStack) gave an error during the TLS handshake.
Nothing we can diagnose further from our side, unfortunately.
Hi @ccall48
Did you manage to get it working? Talking to Johan now to see if they see anything on their end but I guess we are facing the same problem you did.
Unfortunately not yet. nothing I have tried seems to work, I spent a few weeks on this too =/
If you have any wins please let me know!
