I modified chirpstack-gateway-bridge.toml file for using basicstaion as below.
# Backend type.
# Valid options are:
# * semtech_udp
# * concentratord
# * basic_station
type="basic_station"
# Basic Station backend.
[backend.basic_station]
# ip:port to bind the Websocket listener to.
bind=":3001"
# TLS certificate and key files.
# When set, the websocket listener will use TLS to secure the connections
# between the gateways and ChirpStack Gateway Bridge (optional).
tls_cert=/root/lora-basicstation/tc.trust""
tls_key="/root/lora-basicstation/tc.key"
and also i changed basicstation files, tc.uri file as wss://192.168.20.60:3001 and i created new api key on chirpstack server so tc.key file but when i run station to connect chirpstack i faced error below.
How to connect chirpstack local server using basic station? thanks
