Problem Connection Gateway
Hi all,
I have a problem with a new installation of loraserver.io
When connecting Gateway, “Last seen: Invalid date” appears
I have configured server like other servers, but I receive these errors, could it be a problem of port communication?
may 23 05:15:37 telconsurlora systemd[1]: Started LoRa Server.
may 23 05:15:42 telconsurlora loraserver[890]: time=“2019-05-23T05:15:41Z” level=info msg=“starting LoRa Server” band=EU_863_870 docs=“https:/www.loraserver.io/” net_id=000000 version=3.0.0
may 23 05:15:42 telconsurlora loraserver[890]: time=“2019-05-23T05:15:41Z” level=info msg=“storage: setting up storage module”
may 23 05:15:42 telconsurlora loraserver[890]: time=“2019-05-23T05:15:41Z” level=info msg=“storage: setting up Redis connection pool”
may 23 05:15:42 telconsurlora loraserver[890]: time=“2019-05-23T05:15:41Z” level=info msg=“storage: connecting to PostgreSQL”
may 23 05:15:42 telconsurlora loraserver[890]: time=“2019-05-23T05:15:42Z” level=warning msg=“storage: ping PostgreSQL database error, will retry in 2s” error=“dial tcp [::1]:5432: connect: connection refused”
may 23 05:15:44 telconsurlora loraserver[890]: time=“2019-05-23T05:15:44Z” level=info msg=“storage: applying PostgreSQL data migrations”
may 23 05:15:45 telconsurlora loraserver[890]: time=“2019-05-23T05:15:45Z” level=info msg=“storage: PostgreSQL data migrations applied” count=0
may 23 05:15:45 telconsurlora loraserver[890]: time=“2019-05-23T05:15:45Z” level=info msg=“gateway/mqtt: connecting to mqtt broker” server=“tcp://localhost:1883”
may 23 05:15:45 telconsurlora loraserver[890]: time=“2019-05-23T05:15:45Z” level=info msg=“no geolocation-server configured”
may 23 05:15:45 telconsurlora loraserver[890]: time=“2019-05-23T05:15:45Z” level=info msg=“configuring join-server client” ca_cert= server=“http://localhost:8003” tls_cert= tls_key=
may 23 05:15:45 telconsurlora loraserver[890]: time=“2019-05-23T05:15:45Z” level=info msg=“backend/gateway: connected to mqtt server”
may 23 05:15:45 telconsurlora loraserver[890]: time=“2019-05-23T05:15:45Z” level=info msg=“gateway/mqtt: subscribing to gateway event topic” qos=0 topic=gateway/+/event/+
may 23 05:15:45 telconsurlora loraserver[890]: time=“2019-05-23T05:15:45Z” level=info msg=“starting api server” bind=“0.0.0.0:8000” ca-cert= tls-cert= tls-key=
may 23 05:15:45 telconsurlora loraserver[890]: time=“2019-05-23T05:15:45Z” level=info msg=“starting downlink device-queue scheduler”
may 23 05:15:45 telconsurlora loraserver[890]: time=“2019-05-23T05:15:45Z” level=info msg=“starting multicast scheduler"may 23 05:37:35 telconsurlora loraserver[890]: time=“2019-05-23T05:37:35Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.start_time=“2019-05-23T05:37:35Z” grpc.time_ms=1.084 peer.address=”[::1]:43710" span.kind=server system=grpc
may 23 05:37:36 telconsurlora loraserver[890]: time=“2019-05-23T05:37:36Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetGateway grpc.service=ns.NetworkServerService grpc.start_time=“2019-05-23T05:37:36Z” grpc.time_ms=45.079 peer.address="[::1]:43710" span.kind=server system=grpc
may 23 05:37:36 telconsurlora loraserver[890]: time=“2019-05-23T05:37:36Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.start_time=“2019-05-23T05:37:36Z” grpc.time_ms=13.78 peer.address="[::1]:43710" span.kind=server system=grpc
may 23 13:21:40 telconsurlora loraserver[890]: time=“2019-05-23T13:21:40Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.start_time=“2019-05-23T13:21:40Z” grpc.time_ms=0.73 peer.address="[::1]:43710" span.kind=server system=grpc
may 23 13:21:41 telconsurlora loraserver[890]: time=“2019-05-23T13:21:41Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetGateway grpc.service=ns.NetworkServerService grpc.start_time=“2019-05-23T13:21:41Z” grpc.time_ms=2.53 peer.address="[::1]:43710" span.kind=server system=grpc
may 23 13:21:41 telconsurlora loraserver[890]: time=“2019-05-23T13:21:41Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.start_time=“2019-05-23T13:21:41Z” grpc.time_ms=0.389 peer.address="[::1]:43710" span.kind=server system=grpc
may 23 13:21:59 telconsurlora loraserver[890]: time=“2019-05-23T13:21:59Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.start_time=“2019-05-23T13:21:59Z” grpc.time_ms=0.442 peer.address="[::1]:43710" span.kind=server system=grpc
may 23 13:22:10 telconsurlora loraserver[890]: time=“2019-05-23T13:22:10Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetDeviceProfile grpc.service=ns.NetworkServerService grpc.start_time=“2019-05-23T13:22:10Z” grpc.time_ms=95.035 peer.address="[::1]:43710" span.kind=server system=grpc
may 23 13:22:13 telconsurlora loraserver[890]: time=“2019-05-23T13:22:13Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.start_time=“2019-05-23T13:22:13Z” grpc.time_ms=0.279 peer.address="[::1]:43710" span.kind=server system=grpc
may 23 13:22:15 telconsurlora loraserver[890]: time=“2019-05-23T13:22:15Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetDeviceProfile grpc.service=ns.NetworkServerService grpc.start_time=“2019-05-23T13:22:15Z” grpc.time_ms=1.612 peer.address="[::1]:43710" span.kind=server system=grpc
may 23 13:22:26 telconsurlora loraserver[890]: time=“2019-05-23T13:22:26Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.start_time=“2019-05-23T13:22:26Z” grpc.time_ms=0.692 peer.address="[::1]:43710" span.kind=server system=grpc
may 23 13:23:04 telconsurlora loraserver[890]: time=“2019-05-23T13:23:04Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.start_time=“2019-05-23T13:23:04Z” grpc.time_ms=0.509 peer.address="[::1]:43710" span.kind=server system=grpc
may 23 13:23:06 telconsurlora loraserver[890]: time=“2019-05-23T13:23:06Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetGateway grpc.service=ns.NetworkServerService grpc.start_time=“2019-05-23T13:23:06Z” grpc.time_ms=1.273 peer.address="[::1]:43710" span.kind=server system=grpc
may 23 13:23:06 telconsurlora loraserver[890]: time=“2019-05-23T13:23:06Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.start_time=“2019-05-23T13:23:06Z” grpc.time_ms=0.435 peer.address="[::1]:43710" span.kind=server system=grpc
may 23 13:23:27 telconsurlora loraserver[890]: time=“2019-05-23T13:23:27Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.start_time=“2019-05-23T13:23:27Z” grpc.time_ms=0.724 peer.address="[::1]:43710" span.kind=server system=grpc
root@telconsurlora:~# sudo journalctl -f -n 100 -u lora-app-server
– Logs begin at Mon 2019-05-20 16:02:21 UTC. –
may 23 05:15:45 telconsurlora lora-app-server[888]: time=“2019-05-23T05:15:45Z” level=info msg=“integration/mqtt: connecting to mqtt broker” server=“tcp://localhost:1883”
may 23 05:15:45 telconsurlora lora-app-server[888]: time=“2019-05-23T05:15:45Z” level=info msg=“integration/mqtt: connected to mqtt broker”
may 23 05:15:45 telconsurlora lora-app-server[888]: time=“2019-05-23T05:15:45Z” level=info msg=“integration/mqtt: subscribing to tx topic” qos=0 topic=application/+/device/+/tx
may 23 05:15:45 telconsurlora lora-app-server[888]: time=“2019-05-23T05:15:45Z” level=info msg=“api/as: starting application-server api” bind=“0.0.0.0:8001” ca_cert= tls_cert= tls_key=
may 23 05:15:45 telconsurlora lora-app-server[888]: time=“2019-05-23T05:15:45Z” level=info msg=“api/external: starting api server” bind=“0.0.0.0:8080” tls-cert= tls-key=
may 23 05:15:45 telconsurlora lora-app-server[888]: time=“2019-05-23T05:15:45Z” level=info msg=“api/external: registering rest api handler and documentation endpoint” path=/api
may 23 05:15:45 telconsurlora lora-app-server[888]: time=“2019-05-23T05:15:45Z” level=info msg=“api/js: starting join-server api” bind=“0.0.0.0:8003” ca_cert= tls_cert= tls_key=
may 23 05:37:32 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:32Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Branding grpc.service=api.InternalService grpc.start_time=“2019-05-23T05:37:32Z” grpc.time_ms=0.038 peer.address="[::1]:42184" span.kind=server system=grpc
may 23 05:37:32 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:32Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Profile grpc.service=api.InternalService grpc.start_time=“2019-05-23T05:37:32Z” grpc.time_ms=191.575 peer.address="[::1]:42184" span.kind=server system=grpc
may 23 05:37:32 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:32Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.ApplicationService grpc.start_time=“2019-05-23T05:37:32Z” grpc.time_ms=22.051 peer.address="[::1]:42194" span.kind=server system=grpc
may 23 05:37:33 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:33Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Get grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T05:37:33Z” grpc.time_ms=10.739 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 05:37:33 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:33Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.ApplicationService grpc.start_time=“2019-05-23T05:37:33Z” grpc.time_ms=14.571 peer.address="[::1]:42194" span.kind=server system=grpc
may 23 05:37:33 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:33Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T05:37:33Z” grpc.time_ms=40.324 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 05:37:33 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:33Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Get grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T05:37:33Z” grpc.time_ms=9.626 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 05:37:33 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:33Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T05:37:33Z” grpc.time_ms=10.57 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 05:37:33 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:33Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T05:37:33Z” grpc.time_ms=11.431 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 05:37:33 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:33Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Get grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T05:37:33Z” grpc.time_ms=9.044 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 05:37:34 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:34Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Get grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T05:37:34Z” grpc.time_ms=8.279 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 05:37:34 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:34Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.GatewayService grpc.start_time=“2019-05-23T05:37:34Z” grpc.time_ms=21.048 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 05:37:35 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:35Z” level=warning msg=“creating insecure network-server client” server=“localhost:8000”
may 23 05:37:35 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:35Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.time_ms=25.008 span.kind=client system=grpc
may 23 05:37:35 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:35Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetStats grpc.service=api.GatewayService grpc.start_time=“2019-05-23T05:37:35Z” grpc.time_ms=41.867 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 05:37:36 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:36Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=GetGateway grpc.service=ns.NetworkServerService grpc.time_ms=46.055 span.kind=client system=grpc
may 23 05:37:36 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:36Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Get grpc.service=api.GatewayService grpc.start_time=“2019-05-23T05:37:36Z” grpc.time_ms=56.415 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 05:37:36 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:36Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.time_ms=14.576 span.kind=client system=grpc
may 23 05:37:36 telconsurlora lora-app-server[888]: time=“2019-05-23T05:37:36Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetStats grpc.service=api.GatewayService grpc.start_time=“2019-05-23T05:37:36Z” grpc.time_ms=24.765 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:21:31 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:31Z” level=info msg=“finished unary call with code Unauthenticated” error=“rpc error: code = Unauthenticated desc = authentication failed: get token from context error: no authorization-data in metadata” grpc.code=Unauthenticated grpc.method=List grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T13:21:31Z” grpc.time_ms=0.101 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 13:21:31 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:31Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Branding grpc.service=api.InternalService grpc.start_time=“2019-05-23T13:21:31Z” grpc.time_ms=0.067 peer.address="[::1]:42184" span.kind=server system=grpc
may 23 13:21:31 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:31Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Branding grpc.service=api.InternalService grpc.start_time=“2019-05-23T13:21:31Z” grpc.time_ms=0.048 peer.address="[::1]:42184" span.kind=server system=grpc
may 23 13:21:36 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:36Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Login grpc.service=api.InternalService grpc.start_time=“2019-05-23T13:21:36Z” grpc.time_ms=227.055 peer.address="[::1]:42184" span.kind=server system=grpc
may 23 13:21:36 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:36Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Profile grpc.service=api.InternalService grpc.start_time=“2019-05-23T13:21:36Z” grpc.time_ms=10.612 peer.address="[::1]:42184" span.kind=server system=grpc
may 23 13:21:36 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:36Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T13:21:36Z” grpc.time_ms=14.908 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 13:21:36 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:36Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T13:21:36Z” grpc.time_ms=7.893 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 13:21:36 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:36Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T13:21:36Z” grpc.time_ms=6.685 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 13:21:37 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:37Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Get grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T13:21:37Z” grpc.time_ms=10.131 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 13:21:37 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:37Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.ApplicationService grpc.start_time=“2019-05-23T13:21:37Z” grpc.time_ms=8.539 peer.address="[::1]:42194" span.kind=server system=grpc
may 23 13:21:37 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:37Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T13:21:37Z” grpc.time_ms=6.989 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 13:21:37 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:37Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Get grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T13:21:37Z” grpc.time_ms=9.413 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 13:21:40 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:40Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:21:40Z” grpc.time_ms=10.978 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:21:40 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:40Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.time_ms=1.415 span.kind=client system=grpc
may 23 13:21:40 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:40Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetStats grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:21:40Z” grpc.time_ms=12.324 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:21:41 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:41Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=GetGateway grpc.service=ns.NetworkServerService grpc.time_ms=3.19 span.kind=client system=grpc
may 23 13:21:41 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:41Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Get grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:21:41Z” grpc.time_ms=13.609 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:21:41 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:41Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.time_ms=1.124 span.kind=client system=grpc
may 23 13:21:41 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:41Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetStats grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:21:41Z” grpc.time_ms=8.269 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:21:59 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:59Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:21:59Z” grpc.time_ms=10.187 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:21:59 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:59Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:21:59Z” grpc.time_ms=10.965 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:21:59 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:59Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.time_ms=1.208 span.kind=client system=grpc
may 23 13:21:59 telconsurlora lora-app-server[888]: time=“2019-05-23T13:21:59Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetStats grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:21:59Z” grpc.time_ms=11.522 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:22:00 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:00Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.ApplicationService grpc.start_time=“2019-05-23T13:22:00Z” grpc.time_ms=11.832 peer.address="[::1]:42194" span.kind=server system=grpc
may 23 13:22:02 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:02Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.NetworkServerService grpc.start_time=“2019-05-23T13:22:02Z” grpc.time_ms=10.154 peer.address="[::1]:42186" span.kind=server system=grpc
may 23 13:22:08 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:08Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.DeviceProfileService grpc.start_time=“2019-05-23T13:22:08Z” grpc.time_ms=9.683 peer.address="[::1]:42198" span.kind=server system=grpc
may 23 13:22:10 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:10Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=GetDeviceProfile grpc.service=ns.NetworkServerService grpc.time_ms=96.335 span.kind=client system=grpc
may 23 13:22:10 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:10Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Get grpc.service=api.DeviceProfileService grpc.start_time=“2019-05-23T13:22:10Z” grpc.time_ms=107.204 peer.address="[::1]:42198" span.kind=server system=grpc
may 23 13:22:12 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:12Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:22:12Z” grpc.time_ms=10.978 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:22:13 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:13Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.time_ms=0.84 span.kind=client system=grpc
may 23 13:22:13 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:13Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetStats grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:22:13Z” grpc.time_ms=13.613 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:22:13 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:13Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.DeviceProfileService grpc.start_time=“2019-05-23T13:22:13Z” grpc.time_ms=11.532 peer.address="[::1]:42198" span.kind=server system=grpc
may 23 13:22:15 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:15Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=GetDeviceProfile grpc.service=ns.NetworkServerService grpc.time_ms=2.169 span.kind=client system=grpc
may 23 13:22:15 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:15Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Get grpc.service=api.DeviceProfileService grpc.start_time=“2019-05-23T13:22:15Z” grpc.time_ms=12.106 peer.address="[::1]:42198" span.kind=server system=grpc
may 23 13:22:17 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:17Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.ApplicationService grpc.start_time=“2019-05-23T13:22:17Z” grpc.time_ms=11.665 peer.address="[::1]:42194" span.kind=server system=grpc
may 23 13:22:18 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:18Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.ApplicationService grpc.start_time=“2019-05-23T13:22:18Z” grpc.time_ms=9.246 peer.address="[::1]:42194" span.kind=server system=grpc
may 23 13:22:21 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:21Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=ListUsers grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T13:22:21Z” grpc.time_ms=11.054 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 13:22:24 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:24Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Get grpc.service=api.OrganizationService grpc.start_time=“2019-05-23T13:22:24Z” grpc.time_ms=14.788 peer.address="[::1]:42182" span.kind=server system=grpc
may 23 13:22:26 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:26Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:22:26Z” grpc.time_ms=10.982 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:22:26 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:26Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.time_ms=1.613 span.kind=client system=grpc
may 23 13:22:26 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:26Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetStats grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:22:26Z” grpc.time_ms=12.145 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:22:28 telconsurlora lora-app-server[888]: time=“2019-05-23T13:22:28Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.DeviceProfileService grpc.start_time=“2019-05-23T13:22:28Z” grpc.time_ms=11.327 peer.address="[::1]:42198" span.kind=server system=grpc
may 23 13:23:03 telconsurlora lora-app-server[888]: time=“2019-05-23T13:23:03Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.ApplicationService grpc.start_time=“2019-05-23T13:23:03Z” grpc.time_ms=8.123 peer.address="[::1]:42194" span.kind=server system=grpc
may 23 13:23:04 telconsurlora lora-app-server[888]: time=“2019-05-23T13:23:04Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:23:04Z” grpc.time_ms=7.985 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:23:04 telconsurlora lora-app-server[888]: time=“2019-05-23T13:23:04Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.time_ms=1.286 span.kind=client system=grpc
may 23 13:23:04 telconsurlora lora-app-server[888]: time=“2019-05-23T13:23:04Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetStats grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:23:04Z” grpc.time_ms=11.852 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:23:06 telconsurlora lora-app-server[888]: time=“2019-05-23T13:23:06Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=GetGateway grpc.service=ns.NetworkServerService grpc.time_ms=1.94 span.kind=client system=grpc
may 23 13:23:06 telconsurlora lora-app-server[888]: time=“2019-05-23T13:23:06Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Get grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:23:06Z” grpc.time_ms=9.971 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:23:06 telconsurlora lora-app-server[888]: time=“2019-05-23T13:23:06Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.time_ms=1.239 span.kind=client system=grpc
may 23 13:23:06 telconsurlora lora-app-server[888]: time=“2019-05-23T13:23:06Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetStats grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:23:06Z” grpc.time_ms=12.061 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:23:26 telconsurlora lora-app-server[888]: time=“2019-05-23T13:23:26Z” level=info msg=“finished client streaming call” grpc.code=OK grpc.method=StreamFrameLogsForGateway grpc.service=ns.NetworkServerService grpc.time_ms=0.058 span.kind=client system=grpc
may 23 13:23:27 telconsurlora lora-app-server[888]: time=“2019-05-23T13:23:27Z” level=info msg=“finished client unary call” grpc.code=OK grpc.method=GetGatewayStats grpc.service=ns.NetworkServerService grpc.time_ms=1.35 span.kind=client system=grpc
may 23 13:23:27 telconsurlora lora-app-server[888]: time=“2019-05-23T13:23:27Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=GetStats grpc.service=api.GatewayService grpc.start_time=“2019-05-23T13:23:27Z” grpc.time_ms=11.736 peer.address="[::1]:42192" span.kind=server system=grpc
may 23 13:24:19 telconsurlora lora-app-server[888]: time=“2019-05-23T13:24:19Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.GatewayProfileService grpc.start_time=“2019-05-23T13:24:19Z” grpc.time_ms=25.463 peer.address="[::1]:42204" span.kind=server system=grpc
may 23 13:24:19 telconsurlora lora-app-server[888]: time=“2019-05-23T13:24:19Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=List grpc.service=api.GatewayProfileService grpc.start_time=“2019-05-23T13:24:19Z” grpc.time_ms=10.619 peer.address="[::1]:42204" span.kind=server system=grpc
may 23 14:35:41 telconsurlora lora-app-server[888]: time=“2019-05-23T14:35:41Z” level=info msg=“finished unary call with code OK” grpc.code=OK grpc.method=Branding grpc.service=api.InternalService grpc.start_time=“2019-05-23T14:35:41Z” grpc.time_ms=0.06 peer.address="[::1]:42184" span.kind=server system=grpc
i have the same problem here , did you solve it ?
