Hello everybody.
I’m trying to setup an environment to customize the UI, however, I’m new to the docker … and when running the docker-compose up it logs this:
Building with native build. Learn about native build in Compose here: https://docs.docker.com/go/compose-native-build/
Starting chirpstack-application-server-master_mosquitto_1 ... done
Starting chirpstack-application-server-master_rabbitmq_1 ... done
Starting chirpstack-application-server-master_zookeeper_1 ... done
Starting chirpstack-application-server-master_postgres_1 ... done
Starting chirpstack-application-server-master_redis_1 ... done
Starting chirpstack-application-server-master_kafka_1 ... done
Starting chirpstack-application-server-master_chirpstack-application-server_1 ... done
docker-compose ps (apparently no error):
chirpstack-application-server-master_chirpstack-application-server_1 /bin/sh Exit 0
chirpstack-application-server-master_kafka_1 /opt/bitnami/scripts/kafka ... Up 9092/tcp
chirpstack-application-server-master_mosquitto_1 /docker-entrypoint.sh /usr ... Up 1883/tcp
chirpstack-application-server-master_postgres_1 docker-entrypoint.sh postgres Up 5432/tcp
chirpstack-application-server-master_rabbitmq_1 docker-entrypoint.sh rabbi ... Up 15691/tcp, 15692/tcp, 25672/tcp, 4369/tcp, 5671/tcp, 5672/tcp
chirpstack-application-server-master_redis_1 docker-entrypoint.sh redis ... Up 6379/tcp
chirpstack-application-server-master_zookeeper_1 /opt/bitnami/scripts/zooke ... Up 2181/tcp, 2888/tcp, 3888/tcp, 8080/tcp
But, when running npm start on ./ui it returns this error on requests:
Proxy error: Could not proxy request /swagger/internal.swagger.json from localhost:3000 to http://localhost:8080/.
See https://nodejs.org/api/errors.html#errors_common_system_errors for more information (ECONNREFUSED).
Thanks.
