I have problems to connect my Kerlink Ifemto to my own Lora server.
Is there anyone who has tried it or can help with a guide?
Thanks a lot
Thanks a lot
Yes we have managed to do so. What is the problem you face ? Could you give more details ?
If one of you would like to create a pull-request with the steps needed to setup the Ifemto, that would be great
https://docs.loraserver.io/lora-gateway-bridge/install/gateway/kerlink/
This is the source: https://github.com/brocaar/lora-gateway-bridge/blob/master/docs/content/install/gateway/kerlink.md
I’ve tried following the guide (https://docs.loraserver.io/lora-gateway-bridge/install/gateway/kerlink/), but get a error when I want to create / mnt / - It is a read only system.
so I installed it on /user/fsuser-1/lora-gateway-bridge/bin but can not get it started there.
So I don´t know how to do?
I also ran into the same problem.
Did you find a solution?
i am also searching for a solution.
Was anyone able to install the gateway bridge on the ifemtocell?
