Hi Community,
I have:
- RAK2245 whit fimware 2.9.1R
- Rak811 whit fimware: 3.0.0.1.H
- Use OTAA mode
- Class A
I folowing the “Get Start with RAK811 WisNode-LoRa” V3.0.0.2, and whit TTN work fine.
Whit Loraserver the Gateway RAK2245 is detected for Loraserver, but when use the RAK811 its don´t works:
I get from Loraserver “app_key” and “dev_eui” and send to Rak811. The “app_eui” I don´t use or use the same “dev_eui”.
I use:
at set_config=lora:join_mode:0
at set_config=lora:class:0
at set_config=lora:region:US915
at set_config=lora:dev_eui:xxxx…
at set_config=lora:app_eui:xxx…
at set_config=lora:app_key:xxx
at join
OTAA Join Start…
OK
[LoRa]:Join retry Cnt:1
[LoRa]:Join retry Cnt:2
[LoRa]:Join retry Cnt:3
[LoRa]:Join retry Cnt:4
[LoRa]:Joined Failed!
Can you helpeme, thanks.
