Hi all, hope everything goes fine!
I’ve been using Chirpstack for the last months and everything is OK. I use OTAA and ABP, class A and class C devices.
Now I need to send downlink from server to device, to configure them for example. How is this procedure correctly done?
I read in the forum that I need to generate a random base64 encoded key, then go to chirpstack-application-server.toml file and change the verysecret for the generated code in the line:
jwt_secret = “verysecret”
Once this is done I can go to my server and add /api at the end (localhost:8080/api, in my case).
Use internal login to get JWT and then copy and paste it in the right top corner, where it says JWT TOKEN.
ANY FURTHER HELP/ADVICE FOR THIS ISSUE?
