We have 9 power meters at a construction site, each hooked up to a Milesight UC300 IoT Controller, which is the device that sends the power meter data that it collects via Modbus over LoRaWAN. 12 modbus registers are read, which results in 3 separate packets being sent over LoRaWAN every 10 minutes.
The gateway is about 20 metres from the IoT Controllers.
Here is the weird thing… about 1/3 of the devices seems to send all 3 data packets correctly to Chirpstack, while the rest only send about 2 packets correctly, and then the “invalid MIC” error is thrown for the third packet. Then about every 3 to 4 hours, the third packet is also sent correctly, but then the errors return for another 3-4 hours. We have many other LoRaWAN devices in the same area, mostly Elsys models, and they work fine.
I have tried to run the devices with and without “Disable frame-counter validation” enabled. We have restarted the devices a couple of times, but that didn’t help. They are set up for OTAA.
Edit: Also, very often duplicate packets are sent only seconds apart.
