I retrieved a mutlitech conduit (AEP) with old version of LoRa Gateway Bridge (rev 2.2), and I didn’t find the configuration file in the /var/config/lora-gateway-bridge directory (for the mqtt instance).
So I don’t know how to set the couple username-password to be compliant with my MQTT broker?
Currently I installed LoRa server 0.26.0 and and LoRa appserver 0.20.0 all work fine ;).
if possible plz could you tell me where can I find the mqtt config file with the lora gateway bridge rev 2.2 in my mtcdt ?
And if I have to upgrade with the lora gateway bridge rev 2.4 how can I remove properly the old revision???
Hello @brocaar, I upgraded my lora-gateway-bridge from V2.4 to V3.0 it works but the old commands which was linked with the lora-gateway-bridge seems to have disappeared.
Here my configuration:
Loraserver ==> V.2.8.2
Lora-app-server ==> V.2.6.1
Lora-geo-server ==> V.2.0.1
Lora-gateway-bridge (hosted multitech gw) ==> V.3.0.1 ( before V.2.4.0)
My process:
I renamed the old lora-gateway-bridge.toml to old-lora-gateway-bridge.toml.
I removed [lora-gateway-bridge_2.4.0-r1.0_arm926ejste.ipk] was available in my home directory.
I wanted to regenerate a new one with this command lora-gateway-bridge configfile > lora-gateway-bridge.toml but he command lora-gateway-bridge was not found!
So I copied the template and pasted it in my lora-gateway-bridge.toml then I did the modification according my setup.
I started the lora-gateway-bridge ==> /etc/init.d/lora-gateway-bridge start
The command available are only [start-stop-restart]
To finish I modified the loraserver.toml as specified in the release note.
from the loraserver log I can see the modification of mosquitto topic ‘…/events/stats/…’ ‘…events/up/…’ so on…
Do you tell me if this behavior is the one expected?
What is wrong in my process?
I’m facing the same issue but with the RAK831 gateway with Raspberry Pi3.
After some days of frustation I decided to install again the operative system of the RPi3 and to download again the packet forwarder program and the lora-gateway-bridge, BUT when I install it from zero it also happens to me. The “lora-gateway-bridge.toml” is just a part of the template which is in the documentation.
This makes me think that it could be a problem of the packet that we download from the repository.
