I am running previous stable releases of Chirpstack server stack cloned from chirpstack github repo successfully on windows. Versions are:
as: 3.14.0
ns: 3.12.3
gw_bridge: 3.10.0
When I pull newest version of the server stack I started to face Redis XADD error.
Normally I am getting redis error in image 1 when I start network server. When I assign per_device_frame_log_max_history=0 and per_gateway_frame_log_max_history=0 in the NS toml file, I am not getting the errors on startup of the network server. But I get the error in image 2 and 3 when I want to see device and gateway live frames on the AS UI.
It may be related to new feature named frame logging to a redis stream coming with the newest version of Chirpstack.
Also It looks like there is no redis stream type in redis version 3.2. I use redis 3.2 on windows because windows has just got redis 3.2. I find that Redis streams introduced in redis 5.0.
How can I run newest version of Chirpstack without this error ?
