Hi, i would like to register end devices without using the web ui, im using chirpstack with docker and the API REST in order to achieve that, but the documentation says that gRPC is recommended, but i dont see any examples and i dont understand why gRPC is preferred over API REST, there is my code btw, thanks
import requests
headers = {"accept": "application/json",
"Grpc-Metadata-Authorization": "Bearer eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJhdWQiOiJjaGlycHN0YWNrIiwiaXNzIjoiY2hpcnBzdGFjayIsInN1YiI6ImUzY2IzN2QxLTU4YjYtNGU5Zi05NjY3LWE1NDQ4MzhiNDg5NiIsInR5cCI6ImtleSJ9.UVVh96Gao4nnkmfJHPDKNsrxmsTSadn_xJG3qhh3U14",
"Content-Type": "application/json"}
def get_tenant() -> str:
res = requests.get(
"http://localhost:8090/api/tenants?limit=1", headers=headers)
if res.status_code == 200:
data = res.json()
return data['result'][0]['id']
return ""
TENANT_ID = get_tenant()
GATEWAY_EUI = "f0e910ffab2964e0"
def create_app() -> str:
data = {"application": {
"description": "test",
"id": "test",
"name": "app",
"tenantId": TENANT_ID
res = requests.post(
"http://localhost:8090/api/applications", headers=headers, json=data)
return res.json()['id']
return ""
APP_ID = create_app()
def create_gateway():
data = {
"gateway": {
"description": "",
"gatewayId": GATEWAY_EUI,
"location": {
"accuracy": 0,
"altitude": 0,
"latitude": 0,
"longitude": 0,
"source": "UNKNOWN"
"name": "gateway",
"properties": {
"additionalProp1": "string",
"additionalProp2": "string",
"additionalProp3": "string"
"tags": {
res = requests.post("http://localhost:8090/api/gateways",
create_gateway()
def create_device_profile() -> str:
data = {
"deviceProfile": {
"classBTimeout": 0,
"classCTimeout": 0,
"description": "",
"deviceStatusReqInterval": 1,
"flushQueueOnActivate": True,
"macVersion": "LORAWAN_1_0_3",
"name": "profile",
"payloadCodecRuntime": "CAYENNE_LPP",
"regParamsRevision": "A",
"region": "US915",
"supportsClassB": False,
"supportsClassC": False,
"supportsOtaa": True,
"tenantId": TENANT_ID,
"uplinkInterval": 3600
res = requests.post("http://localhost:8090/api/device-profiles",
return ""
DEVICE_PROFILE_ID = create_device_profile()
def register_device(deveui, name):
data = {
"device": {
"applicationId": APP_ID,
"description": "",
"devEui": deveui,
"deviceProfileId": DEVICE_PROFILE_ID,
"isDisabled": False,
"name": name,
"skipFcntCheck": True,
res = requests.post("http://localhost:8090/api/devices",
print("device registered successfully")
else:
print(res.json())
register_device("1114b10b0022f78a", "node1")
register_device("1114b10b0022f78b", "node2")
register_device("1114b10b0022f78c", "node3")
