ChirpStack Application Server v3.15.0
Features
LoRaWAN 1.0.4
This adds the LoRaWAN 1.0.4 mac-version and RP002-1.0.0 and PR002-1.0.1 regional parameter revisions to the device-profile configuration.
ReEncryptDeviceQueueItems API method (AS)
This implements the ReEncryptDeviceQueueItems
method to the (internal) application-server API. This method is used by ChirpStack Network Server v3.13+ when it needs request the application-server to re-encrypt the device queue-items.
PostgreSQL schema migrations
This implements automatic schema migrations for the PostgreSQL integration. When you have manually created the tables (as documented previously), then these tables will be automatically adopted and updated to the latest version. For newly setup integrations all tables will be created automatically. (#573)
Improvements
- Don’t run Docker container as root. (#520)
- Add gateway downlink info in
txack
message. (#576) - Refactor SQL schema migrations from sql-migrate to golang-migrate. (#585)
- Add option to configure Redis key-prefix.
- Add ns precision to the log timestamps.
- Fix Thingsboard rssi and snr telemetry keys + add fport, fcnt and dr telemetry keys.
- PostgreSQL integration improvements
- Store
confirmed_uplink
anddev_addr
for uplink. (#579) - Use
marshaler
configuration when encodingrx_info
to JSON. - Add
tx_info
field for uplinks. - Store
txack
payloads into PostgreSQL database.
- Store
