ChirpStack Application Server v3.9.0
Features
Monitoring
The monitoring configuration has been updated so that it is possible to configure both a Prometheus endpoint at /metrics
and healthcheck endpoint at /health
. This change is backwards compatible, but to use the /health
endpoint you must update your configuration.
Gateway tags and metadata
This makes it possible to store additional user-defined key/value configuration per gateway. Metadata pushed by the ChirpStack Gateway Bridge is now stored by the ChirpStack Application Server and visible under metadata.
Device-profile tags
This makes it possible to store additional user-defined key/value configuration per device-profile.
myDevices Cayenne
The myDevices Cayenne endpoint is now enabled for the myDevices integration.
Improvements
- Implement searching devices by tags (e.g.
tagname:tagvalue
). - Refactor Prometheus endpoint and add
/health
endpoint.
Bugfixes
- Update gRPC dependency to fix ‘DNS name does not exist’ error. (#426)
