ChirpStack Network Server v3.5.0
Features
RX1 / RX2 selection logic
New configuration options have been added for RX1 / RX2 selection for downlink. (#429)
- Using
rx2_prefer_on_rx1_dr_lt
it is possible to prefer RX2 for downlink, when the RX1 data-rate is less than the configured value. - Using
rx2_prefer_on_link_budget
it is possible to prefer RX2 for downlink when RX2 provides a better link budget than RX1.
Mac-command error handling
A new configuration option has been added to limit the number of mac-command errors (per device). This resolves the issue where the Network Server keeps trying to send a downlink mac-command to a malfunctioning device.
RPM packaging
This is the first release providing .rpm packages for CentOS and RedHat. (#454)
Improvements
Update lorawan package
The updated version contains logic for the EU868 band to either use 14 dBm or 27 dBm based on used frequency.
gRPC / Protobuf cleanup
All definitions are now imported from github.com/brocaar/chirpstack-api/go
. When using the gRPC API, you must update your imports.
Environment variable configuration
Deprecate use of dots (.
) in environment variable names, use double understore (__
) instead. (#451)
Antenna diversity
Update lock key of MQTT gateway backend for handling of antenna diversity.
Internal improvements
The (re)usage of Redis connections has been improved.
