ChirpStack Network Server v3.9.0-test.1
Features
Redis Cluster and Sentinel
This release introduces the support for Redis Cluster and Redis Sentinel.
Rejected uplink callback to Network Controller
A new API method has been added to the (optional) Network Controller called HandleRejectedUplinkFrameSet
. When ChirpStack Network Server rejects an uplink (e.g. when the device is not known to the network, or the activation is missing), it will call this method (when the Network Controller is configured).
Testing
Debian
Use the testing
channel instead of stable
sudo echo "deb https://artifacts.chirpstack.io/packages/3.x/deb testing main" | sudo tee /etc/apt/sources.list.d/chirpstack.list
Docker
Use the chirpstack/chirpstack-network-server:3.9.0-test.1
image and tag (will be available shortly).
