LoRa Gateway Bridge v3.3.0
Features
Message IDs
This release implements unique message IDs (both for events and commands) that can be used for correlation or logging purposes.
BasicStation channel-plan configuration
To make it easier to work with the BasicStation Packet Forwarder, this release makes it possible to configure the channel-plan inside the LoRa Gateway Bridge configuration file. It is no longer needed to configure a Gateway Profile within LoRa App Server. This means that it is also possible to use the LoRa Gateway Bridge with BasicStation gateways, without the need of installing LoRa Server and LoRa App Server.
