I’ve just released LoRa Server v2.6.0-test1.
Next to some small changes listed below, parts of the code-base has been cleaned up internally. Before pushing this to the stable APT channel (and the loraserver:2
Docker tag), I’m looking forward to your feedback!
Debian / Ubuntu
sudo echo "deb https://artifacts.loraserver.io/packages/2.x/deb testing main" | sudo tee /etc/apt/sources.list.d/loraserver.list
Docker
Use the loraserver/loraserver:2.6.0-test1
image.
Manual download
https://artifacts.loraserver.io/downloads/loraserver/
Features
- On ADR, decrease device DR when the device is using a higher DR than the maximum DR set in the service-profile. #375
Bugfixes
- Implement missing
DeviceModeReq
mac-command for LoRaWAN 1.1. #371 - Fix triggering gateway config update. #373
Improvements
- Internal code-cleanup with regards to passing configuration and objects.
- Internal migration from Dep to Go modules.
