Rename to ChirpStack announcement
Hi @brocaar, we updated to the latest release with bugfixes. Now, two cases were generated:
On the system where chirpstack-network-server , chirpstack-application-server, chirpstack-gateway-bridge were all on one instance/VM , the update made everything work fine.
But on a distributed system, where chirpstack-application-server was on a different instance and chirpstack-network-server + chirpstack-gateway-bridge was on another different instance, we could not see the last seen of the gateways as well as it is not able to get devices from the applications tab, on clicking it is showing “object does not exists.” We checked the host:port in all the config files, and the entries are correct. How can we solve this?
Thank you!
