Hi brocaar,
There’s an error as follow while adding new device.
[2420][08:27:15]INFO: Received pkt from mote: 005896c2 (fcnt=16876)
[2420][08:27:15]JSON up: {“rxpk”:[{“tmst”:1017421412,“chan”:6,“rfch”:1,“freq”:482.700000,“stat”:1,“modu”:“LORA”,“datr”:“SF10BW125”,“codr”:“4/5”,“lsnr”:10.5,“rssi”:-73,“size”:18,“data”:“QMKWWAAA7EEEVALX9Hy7CPDK”}]}
[2420][08:27:15]INFO: [up] PUSH_ACK received in 0 ms
[2420][08:27:15]INFO: [up] thread up use 2028 ms,lost ack:0
[2420][08:27:16]INFO: [down] PULL_RESP received - token[224:197]
[2420][08:27:16]JSON down: {“txpk”:{“imme”:false,“rfch”:0,“powe”:14,“ant”:0,“brd”:0,“tmst”:1018421412,“freq”:503.1,“modu”:“LORA”,“datr”:“SF10BW125”,“codr”:“4/5”,“ipol”:true,“size”:43,“data”:“YMKWWACAkDEAVtyrRlqYXWIqcGfnFffYvuK86nbM9GVBW+uMsJbuX7uc3Q==”}}
[2420][08:27:16]INFO: RF Power adjusted to 17 from 14
[2420][08:27:16]ERROR: Packet REJECTED (jit error=2)
[2420][08:27:16]JSON down: {“txpk”:{“imme”:false,“rfch”:0,“powe”:14,“ant”:0,“brd”:0,“tmst”:1018421412,“freq”:505.3,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“ipol”:true,“size”:43,“data”:“YMKWWACAkDEAVtyrRlqYXWIqcGfnFffYvuK86nbM9GVBW+uMsJbuX7uc3Q==”}}
dBm is set to 17 in lora gateway.
any suggestion is appreciated.
Thanks,
Bruce
