Hello All, @brocaar
I implemented Roaming with my Chirpstack Server.
Objects correctly provisionned via OTAA (application server) .
Data received, but where to see those data?
Why i have a result code=other and not “success”?
anv. 27 10:00:05 dtap-Z800 chirpstack-network-server[1496]: time=“2022-01-27T10:00:05.757299993+01:00” level=info msg=“roaming: api request received” async_client=false ctx_id=b01a7a7d-caea-4e20-b30e-94e3f9b10fc8 message_type=PRStartReq receiver_id=000000 sender_id=000001 transaction_id=100
janv. 27 10:00:05 dtap-Z800 chirpstack-network-server[1496]: time=“2022-01-27T10:00:05.757437593+01:00” level=info msg=“api/roaming: returned response” ctx_id=b01a7a7d-caea-4e20-b30e-94e3f9b10fc8 message_type=PRStartAns receiver_id=000001 result_code=Other sender_id=000000 transaction_id=100
janv. 27 10:00:05 dtap-Z800 chirpstack-network-server[1496]: time=“2022-01-27T10:00:05.766013352+01:00” level=info msg=“roaming: api request received” async_client=false ctx_id=3e9aa0d3-e3a0-4920-8ca0-1cc60b8721dd message_type=PRStartReq receiver_id=000000 sender_id=000001 transaction_id=100
janv. 27 10:00:05 dtap-Z800 chirpstack-network-server[1496]: time=“2022-01-27T10:00:05.766079573+01:00” level=info msg=“api/roaming: returned response” ctx_id=3e9aa0d3-e3a0-4920-8ca0-1cc60b8721dd message_type=PRStartAns receiver_id=000001 result_code=Other sender_id=000000 transaction_id=100
janv. 27 10:00:05 dtap-Z800 chirpstack-network-server[1496]: time=“2022-01-27T10:00:05.784000789+01:00” level=info msg=“roaming: api request received” async_client=false ctx_id=e71b0c26-9883-4836-90ce-5351686a9de0 message_type=PRStartReq receiver_id=000000 sender_id=000001 transaction_id=100
janv. 27 10:00:05 dtap-Z800 chirpstack-network-server[1496]: time=“2022-01-27T10:00:05.784067553+01:00” level=info msg=“api/roaming: returned response” ctx_id=e71b0c26-9883-4836-90ce-5351686a9de0 message_type=PRStartAns receiver_id=000001 result_code=Other sender_id=000000 transaction_id=100
janv. 27 11:00:04 dtap-Z800 chirpstack-network-server[1496]: time=“2022-01-27T11:00:04.271913401+01:00” level=info msg=“roaming: api request received” async_client=false ctx_id=aca51c21-affe-4a7c-a2b7-1ddf694dc6eb message_type=PRStartReq receiver_id=000000 sender_id=000001 transaction_id=100
janv. 27 11:00:04 dtap-Z800 chirpstack-network-server[1496]: time=“2022-01-27T11:00:04.272024124+01:00” level=info msg=“api/roaming: returned response” ctx_id=aca51c21-affe-4a7c-a2b7-1ddf694dc6eb message_type=PRStartAns receiver_id=000001 result_code=Other sender_id=000000 transaction_id=100
janv. 27 11:00:04 dtap-Z800 chirpstack-network-server[1496]: time=“2022-01-27T11:00:04.290094211+01:00” level=info msg=“roaming: api request received” async_client=false ctx_id=2b9cecc4-f0d8-4e74-b07f-ddd1f8fb1347 message_type=PRStartReq receiver_id=000000 sender_id=000001 transaction_id=100
janv. 27 11:00:04 dtap-Z800 chirpstack-network-server[1496]: time=“2022-01-27T11:00:04.290182351+01:00” level=info msg=“api/roaming: returned response” ctx_id=2b9cecc4-f0d8-4e74-b07f-ddd1f8fb1347 message_type=PRStartAns receiver_id=000001 result_code=Other sender_id=000000 transaction_id=100
janv. 27 11:00:04 dtap-Z800 chirpstack-network-server[1496]: time=“2022-01-27T11:00:04.293302368+01:00” level=info msg=“roaming: api request received” async_client=false ctx_id=16ad276b-a17e-40d7-bf0a-e89334562355 message_type=PRStartReq receiver_id=000000 sender_id=000001 transaction_id=100
janv. 27 11:00:04 dtap-Z800 chirpstack-network-server[1496]: time=“2022-01-27T11:00:04.293389977+01:00” level=info msg=“api/roaming: returned response” ctx_id=16ad276b-a17e-40d7-bf0a-e89334562355 message_type=PRStartAns receiver_id=000001 result_code=Other sender_id=000000 transaction_id=100
janv. 27 11:00:04 dtap-Z800 chirpstack-network-server[1496]: time=“2022-01-27T11:00:04.332747723+01:00” level=info msg=“roaming: api request received” async_client=false ctx_id=c49ca1a5-4b4e-4d3a-a0b8-5d0d25c7860a message_type=PRStartReq receiver_id=000000 sender_id=000001 transaction_id=100
janv. 27 11:00:04 dtap-Z800 chirpstack-network-server[1496]: time=“2022-01-27T11:00:04.332846753+01:00” level=info msg=“api/roaming: returned response” ctx_id=c49ca1a5-4b4e-4d3a-a0b8-5d0d25c7860a message_type=PRStartAns receiver_id=000001 result_code=Other sender_id=000000 transaction_id=100
Best regards,
Saya
