Hi.
As response of an uplink message, I send informations to the node.
The node opens fine its RX window a couple of seconds after the uplink end.
When the node opens the RX window, I have the message in the downlink queue.
The network server doesn’t send the message to the node.
I tried to solve it by putting a long time between uplink and rx1
I also tried to activate rx2 window.
To permit the downlink message to reach the node, I must do another uplink message a couple of seconds after the first uplink.
Is it normal? I thought that the rx window was made to receive answer to uplink message. Isn’t it the case?
If yes, do you have an idea?
Thanks a lot for your help.
