I have a Sandbox LORAGO PORT installed but can’t get it working. It says that concentratord “does not exists”.
I left the reset pin at 0.
Below part of the log messages
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Setting up concentrator channels
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Configuring multi-SF LoRa chann channel, enabled: true, freq: 868300000, rf_chain: 1, if_f
Oct 08 18:22:55 raspberrypi3 user.info chirpstack-concentratord-sx1301[1615]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
Oct 08 18:22:55 raspberrypi3 user.info chirpstack-concentratord-sx1301[1615]: Starting the concentrator
Oct 8 18:22:56 raspberrypi3 user.err chirpstack-gateway-bridge[884]: time=“2020-10-08T18:22:56Z” level=error msg=“backend/concentratord: event socket dial error” error
Oct 8 18:22:59 raspberrypi3 user.err chirpstack-gateway-bridge[884]: time=“2020-10-08T18:22:59Z” level=error msg=“backend/concentratord: event socket dial error” error
Oct 8 18:23:03 raspberrypi3 user.err chirpstack-gateway-bridge[884]: time=“2020-10-08T18:23:03Z” level=error msg=“backend/concentratord: event socket dial error” error
Oct 8 18:23:05 raspberrypi3 user.err monit[405]: ‘chirpstack-concentratord’ process is not running
Oct 8 18:23:05 raspberrypi3 user.info monit[405]: ‘chirpstack-concentratord’ trying to restart
Oct 8 18:23:05 raspberrypi3 user.info monit[405]: ‘chirpstack-concentratord’ start: ‘/etc/init.d/chirpstack-concentratord start’
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Configuring reset pin, pin: 0
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Starting Concentratord SX1301 (version: 3.0.2, docs: https://www.chirpstack.io/concentrato
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Triggering concentrator reset
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Setting spi device path, spidev_path: /dev/spidev0.0
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Setting board configuration, lorawan_public: true, clock_source: 1
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Setting up concentrator radios
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257
Oct 08 18:23:05 raspberrypi3 user.info chirpstack-concentratord-sx1301[1621]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257
Regards
