Search by Device Address value
Is there a way whereby a user can search by Device Address in the Application Portal or by API? We often want to test Gateways and check what devices on our network they are picking up. In the Gateway frame you can see the Device Address but as yet we have not been able to find a way of searching through our device addresses for any of the displayed device addresses.
This is (not yet) implemented currently.
Thanks Orne. I was expecting an answer from someone pointing out something very obvious. Look forward to the functionality hopefully appearing sometime. :slight_smile:
Best would be to create an issue in the ChirpStack Application Server repo with this feature request to make sure it is tracked somewhere :slight_smile:
OK - will do. Thanks!
