I use the latest version of the Chirpstack server on a Docker on AWS ubuntu micro version(the lightest version of ubuntu possible on the cloud), together with a LORIX One device and 2 GPS trackers from Antratek Browan.
I’m calling you because I encountered a problem related to sending setting/configuration messages to these 2 devices. When the Chirpstack server was running on my PC, the messages were sent instantly after receiving a message from the device I wanted to configure. After I moved everything to AWS, the messages remain in the queue, and the pending always remains on NO.
Following some questions related to this one,I managed to lower 2 values from chirpstack config:
deduplication_delay=“200ms”
get_downlink_data_delay=“100ms”,
down to 50ms and up to 1000ms, but nothing happened.
Plus, when I ran the entire architecture on an Ubuntu machine from AWS, but this time medium (2 CPU and 4 Gb RAM), it worked.
Do you have some ideas about what changes I can do to run this config on a micro VM (1CPU and 1 Gb RAM)?
Thank you!
