Can device variables defined from Devices->Configuration->Variables be modified via MQTT or HTTP commands? I guess the response is no but I wanted to double-check.
Thanks in advance.
Thanks in advance.
Tags and variables can be set as part of the /api/devices
endpoint via REST API, or with a similar call via gRPC.
Anything that you can do via the web UI can be done via API (again, gRPC or REST).
