Hi, Im trying to set up HTTP integration in ChirpStack to forward json data into Splunk via the HTTP Event Collector, however when the data is sent, Splunk reports "ERROR HttpInputDataHandler… reply=5… parsing_err=“No data” "
I’ve been logging the data sent to the Splunk server from the Chirpstack server with wireshark. If i pull the JSON data and URI from each packet, and send that to Splunk via CURL instead, it imports just fine and i get a Success response back from Splunk.
Has anyone had a similar issue in the past? I’ve found essentially nothing on a Chirpstack/Splunk stack out there.
