I have a Raspberry pi3 and ic880A. I have followed the setup as described in https://github.com/MarinoMtz/ic880A_Raspberry.git and my goal is to forward all the sensor data to a chirpstack-bridge.
Although, all the chirpstack stack, i.e. bridge, network and application server etc seem to run properly and my raspberry can ping the chripstack-bridge, I’m not sure what I’m doing wrong and I don’t receive any data.
I’m trying to break down the connections to see where the problem is. Currently, I’m trying to check the following:
- If the ic880A is connected properly to the raspberry (Is there any diagnostic test tool?)
- if the ic880A gets data from my sensors (Is there any analyzer or something for that?)
- If the raspberry-pi sents data to the computer that has the chirpstack-bridge (if the server has ip 192.168.1.5:1700 udp, I suppose wireshark or an equivalent toll is enough, any other recommendations are wellcome)
- If I have appropriate data check that the bridge has the data availabe (Any diagnostic tool for that or just packet analyzer like wireshark is enough?)
Thanks in advance
