i add the log’s printf in handleUplinkMACCommands function, and adr.HandleADR function, they will printf the uplink’s mac-commands and LinkADRReq mac-command.
and the log’s of loraserver
INFO[0000] hello this is main func
INFO[0000] starting LoRa Server band=“CN_470_510” docs=“https://docs.loraserver.io/” net_id=010203 version=0.21.0-8-gce5d8d4
INFO[0000] setup redis connection pool url=“redis://localhost:6379”
INFO[0000] connecting to postgresql
INFO[0000] backend/gateway: connecting to mqtt broker server=“tcp://localhost:1883”
INFO[0000] connecting to application-server ca-cert= server=“127.0.0.1:8001” tls-cert= tls-key=
INFO[0000] no network-controller configured
INFO[0000] starting api server bind=“0.0.0.0:8000” ca-cert= tls-cert= tls-key=
INFO[0000] starting gateway api server bind=“0.0.0.0:8002” ca-cert= tls-cert= tls-key=
INFO[0000] backend/gateway: connected to mqtt server
INFO[0000] backend/gateway: subscribing to rx topic topic=“gateway/+/rx”
INFO[0000] backend/gateway: subscribing to stats topic topic=“gateway/+/stats”
INFO[0002] backend/gateway: rx packet received
2017/11/17 10:04:25 len(FHDR) = 7 fOptsLen=0
INFO[0003] backend/gateway: rx packet received
INFO[0003] hello this is setContextFromDataPHYPayload func, ctx.phyload {{ConfirmedDataUp LoRaWANR1} 0xc4206ea320 3c8efbd0}rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1028647916 472700000 4 0 1 4/5 -37 13.5 39 {LORA 12 125 0}} {1c40e80081fefffe 0001-01-01 00:00:00 +0000 UTC 3497655764 472700000 4 0 1 4/5 -107 -11.5 39 {LORA 12 125 0}}]
INFO[0003] hello this is getNodeSessionForDataUp func
INFO[0003] hello this is GetNodeSessionForPHYPayload func, {57f97cbf {true false false false 0} 72 []}
INFO[0003] the FCnt is valid, validate the MIC
INFO[0003] micok = true err =
INFO[0003] hello this is logDataFramesCollected func
INFO[0003] packet(s) collected dev_eui=9bf728017a881379 gw_count=2 gw_macs=“1c40e800403dfffe, 1c40e80081fefffe” mtype=ConfirmedDataUp
INFO[0003] hello this is decryptFRMPayloadMACCommands func
INFO[0003] hello this is sendRXInfoToNetworkController func, rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1028647916 472700000 4 0 1 4/5 -37 13.5 39 {LORA 12 125 0}} {1c40e80081fefffe 0001-01-01 00:00:00 +0000 UTC 3497655764 472700000 4 0 1 4/5 -107 -11.5 39 {LORA 12 125 0}}]
INFO[0003] rx info sent to network-controller dev_eui=9bf728017a881379
INFO[0003] hello this is handleFOptsMACCommands func
INFO[0003] hello this is handleFRMPayloadMACCommands func
INFO[0003] hello this is sendFRMPayloadToApplicationServer func
INFO[0003] hello this is handleChannelReconfiguration func
INFO[0003] hello this hs handleADR func
INFO[0003] xxxxxxxxxxxxxxxxxxxxxx on HandleADR func
INFO[0003] LinkADRReq’s Payload CID=LinkADRReq ChMask=[true true true true true true true true true true true true true true true true] ChMaskCntl=0 DataRate=5 NbRep=2 TXPower=4
INFO[0003] mac-command block added to queue cid=LinkADRReq dev_eui=9bf728017a881379 frmpayload=false
INFO[0003] adr request added to mac-command queue dev_eui=9bf728017a881379 dr=0 nb_trans=1 req_dr=5 req_nb_trans=2 req_tx_power_idx=4 tx_power=0
INFO[0003] hello this is setLastRXInfoSet func
INFO[0003] hello this is syncUplinkFCnt func
INFO[0003] hello this is saveNodeSession func
INFO[0003] node-session saved dev_addr=57f97cbf dev_eui=9bf728017a881379
INFO[0003] hello this is handleUplinkACK func
INFO[0003] hello this is handleDownlink func
INFO[0003] pending mac-command block set cid=LinkADRReq commands=1 dev_eui=9bf728017a881379 frm_payload=false
INFO[0003] mac-command block removed from queue cid=LinkADRReq dev_eui=9bf728017a881379
INFO[0003] backend/gateway: publishing tx packet topic=“gateway/1c40e800403dfffe/tx”
INFO[0006] backend/gateway: gateway stats packet received mac=1c40e80081fefffe
INFO[0006] gateway updated mac=1c40e80081fefffe
INFO[0009] backend/gateway: gateway stats packet received mac=1c40e800403dfffe
INFO[0009] gateway updated mac=1c40e800403dfffe
INFO[0014] backend/gateway: rx packet received
2017/11/17 10:04:37 len(FHDR) = 9 fOptsLen=2
INFO[0014] hello this is setContextFromDataPHYPayload func, ctx.phyload {{ConfirmedDataUp LoRaWANR1} 0xc4206ebf90 96437c3a}rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1040258540 473100000 6 0 1 4/5 -37 9.3 41 {LORA 7 125 0}} {1c40e80081fefffe 0001-01-01 00:00:00 +0000 UTC 3509266396 473100000 6 0 1 4/5 -107 -4 41 {LORA 7 125 0}}]
INFO[0014] hello this is getNodeSessionForDataUp func
INFO[0014] hello this is GetNodeSessionForPHYPayload func, {57f97cbf {true false false false 2} 73 [{LinkADRReq 0xc4202c9f73}]}
INFO[0014] the FCnt is valid, validate the MIC
INFO[0014] micok = true err =
INFO[0014] hello this is logDataFramesCollected func
INFO[0014] packet(s) collected dev_eui=9bf728017a881379 gw_count=2 gw_macs=“1c40e800403dfffe, 1c40e80081fefffe” mtype=ConfirmedDataUp
INFO[0014] hello this is decryptFRMPayloadMACCommands func
INFO[0014] hello this is sendRXInfoToNetworkController func, rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1040258540 473100000 6 0 1 4/5 -37 9.3 41 {LORA 7 125 0}} {1c40e80081fefffe 0001-01-01 00:00:00 +0000 UTC 3509266396 473100000 6 0 1 4/5 -107 -4 41 {LORA 7 125 0}}]
INFO[0014] rx info sent to network-controller dev_eui=9bf728017a881379
INFO[0014] hello this is handleFOptsMACCommands func
INFO[0014] hello this is handleUplinkMACCommands func
INFO[0014] FOpts info cid=LinkADRReq dev_eui=9bf728017a881379 payload=&{true true true}
INFO[0014] printf Fpots key
INFO[0014] mac-command block removed from pending cid=LinkADRReq dev_eui=9bf728017a881379
INFO[0014] link_adr request acknowledged dev_eui=9bf728017a881379 dr=5 enabled_channels=[0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95] nb_trans=2 tx_power_idx=4
INFO[0014] hello this is handleFRMPayloadMACCommands func
INFO[0014] hello this is sendFRMPayloadToApplicationServer func
INFO[0014] hello this is handleChannelReconfiguration func
INFO[0014] hello this hs handleADR func
INFO[0014] hello this is setLastRXInfoSet func
INFO[0014] hello this is syncUplinkFCnt func
INFO[0014] hello this is saveNodeSession func
INFO[0014] node-session saved dev_addr=57f97cbf dev_eui=9bf728017a881379
INFO[0014] hello this is handleUplinkACK func
INFO[0014] hello this is handleDownlink func
INFO[0014] backend/gateway: publishing tx packet topic=“gateway/1c40e800403dfffe/tx”
INFO[0016] backend/gateway: rx packet received
2017/11/17 10:04:38 len(FHDR) = 7 fOptsLen=0
2017/11/17 10:04:39 len(FHDR) = 7 fOptsLen=0
INFO[0016] hello this is setContextFromDataPHYPayload func, ctx.phyload {{ConfirmedDataUp LoRaWANR1} 0xc4202f1180 88709c92}rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1042042284 472900000 5 0 1 4/5 -35 7.8 39 {LORA 7 125 0}} {1c40e80081fefffe 0001-01-01 00:00:00 +0000 UTC 3511050140 472900000 5 0 1 4/5 -107 -7 39 {LORA 7 125 0}}]
INFO[0016] hello this is getNodeSessionForDataUp func
INFO[0016] hello this is GetNodeSessionForPHYPayload func, {57f97cbf {true false false false 0} 74 []}
INFO[0016] the FCnt is valid, validate the MIC
INFO[0016] micok = true err =
INFO[0016] hello this is logDataFramesCollected func
INFO[0016] packet(s) collected dev_eui=9bf728017a881379 gw_count=2 gw_macs=“1c40e800403dfffe, 1c40e80081fefffe” mtype=ConfirmedDataUp
INFO[0016] hello this is decryptFRMPayloadMACCommands func
INFO[0016] hello this is sendRXInfoToNetworkController func, rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1042042284 472900000 5 0 1 4/5 -35 7.8 39 {LORA 7 125 0}} {1c40e80081fefffe 0001-01-01 00:00:00 +0000 UTC 3511050140 472900000 5 0 1 4/5 -107 -7 39 {LORA 7 125 0}}]
INFO[0016] rx info sent to network-controller dev_eui=9bf728017a881379
INFO[0016] hello this is handleFOptsMACCommands func
INFO[0016] hello this is handleFRMPayloadMACCommands func
INFO[0016] hello this is sendFRMPayloadToApplicationServer func
INFO[0016] hello this is handleChannelReconfiguration func
INFO[0016] hello this hs handleADR func
INFO[0016] hello this is setLastRXInfoSet func
INFO[0016] hello this is syncUplinkFCnt func
INFO[0016] hello this is saveNodeSession func
INFO[0016] node-session saved dev_addr=57f97cbf dev_eui=9bf728017a881379
INFO[0016] hello this is handleUplinkACK func
INFO[0016] hello this is handleDownlink func
INFO[0016] backend/gateway: publishing tx packet topic=“gateway/1c40e800403dfffe/tx”
INFO[0023] backend/gateway: rx packet received
2017/11/17 10:04:46 len(FHDR) = 7 fOptsLen=0
INFO[0023] hello this is setContextFromDataPHYPayload func, ctx.phyload {{ConfirmedDataUp LoRaWANR1} 0xc4203280f0 fabc3273}rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1049300523 472500000 3 0 1 4/5 -36 9 39 {LORA 7 125 0}} {1c40e80081fefffe 0001-01-01 00:00:00 +0000 UTC 3518308379 472500000 3 0 1 4/5 -107 -6.3 39 {LORA 7 125 0}}]
INFO[0023] hello this is getNodeSessionForDataUp func
INFO[0023] hello this is GetNodeSessionForPHYPayload func, {57f97cbf {true false false false 0} 75 []}
INFO[0023] the FCnt is valid, validate the MIC
INFO[0023] micok = true err =
INFO[0023] hello this is logDataFramesCollected func
INFO[0023] packet(s) collected dev_eui=9bf728017a881379 gw_count=2 gw_macs=“1c40e800403dfffe, 1c40e80081fefffe” mtype=ConfirmedDataUp
INFO[0023] hello this is decryptFRMPayloadMACCommands func
INFO[0023] hello this is sendRXInfoToNetworkController func, rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1049300523 472500000 3 0 1 4/5 -36 9 39 {LORA 7 125 0}} {1c40e80081fefffe 0001-01-01 00:00:00 +0000 UTC 3518308379 472500000 3 0 1 4/5 -107 -6.3 39 {LORA 7 125 0}}]
INFO[0023] rx info sent to network-controller dev_eui=9bf728017a881379
INFO[0023] hello this is handleFOptsMACCommands func
INFO[0023] hello this is handleFRMPayloadMACCommands func
INFO[0023] hello this is sendFRMPayloadToApplicationServer func
INFO[0023] hello this is handleChannelReconfiguration func
INFO[0023] hello this hs handleADR func
INFO[0023] hello this is setLastRXInfoSet func
INFO[0023] hello this is syncUplinkFCnt func
INFO[0023] hello this is saveNodeSession func
INFO[0023] node-session saved dev_addr=57f97cbf dev_eui=9bf728017a881379
INFO[0023] hello this is handleUplinkACK func
INFO[0023] hello this is handleDownlink func
INFO[0023] backend/gateway: publishing tx packet topic=“gateway/1c40e800403dfffe/tx”
INFO[0034] backend/gateway: rx packet received
2017/11/17 10:04:57 len(FHDR) = 7 fOptsLen=0
INFO[0035] hello this is setContextFromDataPHYPayload func, ctx.phyload {{ConfirmedDataUp LoRaWANR1} 0xc4203290e0 363aac74}rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1060674380 473100000 6 0 1 4/5 -32 9.5 39 {LORA 7 125 0}} {1c40e80081fefffe 0001-01-01 00:00:00 +0000 UTC 3529682236 473100000 6 0 1 4/5 -108 -4.3 39 {LORA 7 125 0}}]
INFO[0035] hello this is getNodeSessionForDataUp func
INFO[0035] hello this is GetNodeSessionForPHYPayload func, {57f97cbf {true false false false 0} 76 []}
INFO[0035] the FCnt is valid, validate the MIC
INFO[0035] micok = true err =
INFO[0035] hello this is logDataFramesCollected func
INFO[0035] packet(s) collected dev_eui=9bf728017a881379 gw_count=2 gw_macs=“1c40e800403dfffe, 1c40e80081fefffe” mtype=ConfirmedDataUp
INFO[0035] hello this is decryptFRMPayloadMACCommands func
INFO[0035] hello this is sendRXInfoToNetworkController func, rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1060674380 473100000 6 0 1 4/5 -32 9.5 39 {LORA 7 125 0}} {1c40e80081fefffe 0001-01-01 00:00:00 +0000 UTC 3529682236 473100000 6 0 1 4/5 -108 -4.3 39 {LORA 7 125 0}}]
INFO[0035] rx info sent to network-controller dev_eui=9bf728017a881379
INFO[0035] hello this is handleFOptsMACCommands func
INFO[0035] hello this is handleFRMPayloadMACCommands func
INFO[0035] hello this is sendFRMPayloadToApplicationServer func
INFO[0035] hello this is handleChannelReconfiguration func
INFO[0035] hello this hs handleADR func
INFO[0035] xxxxxxxxxxxxxxxxxxxxxx on HandleADR func
INFO[0035] LinkADRReq’s Payload CID=LinkADRReq ChMask=[true true true true true true true true true true true true true true true true] ChMaskCntl=0 DataRate=5 NbRep=3 TXPower=7
INFO[0035] mac-command block added to queue cid=LinkADRReq dev_eui=9bf728017a881379 frmpayload=false
INFO[0035] adr request added to mac-command queue dev_eui=9bf728017a881379 dr=5 nb_trans=2 req_dr=5 req_nb_trans=3 req_tx_power_idx=7 tx_power=4
INFO[0035] hello this is setLastRXInfoSet func
INFO[0035] hello this is syncUplinkFCnt func
INFO[0035] hello this is saveNodeSession func
INFO[0035] node-session saved dev_addr=57f97cbf dev_eui=9bf728017a881379
INFO[0035] hello this is handleUplinkACK func
INFO[0035] hello this is handleDownlink func
INFO[0035] pending mac-command block set cid=LinkADRReq commands=1 dev_eui=9bf728017a881379 frm_payload=false
INFO[0035] mac-command block removed from queue cid=LinkADRReq dev_eui=9bf728017a881379
INFO[0035] backend/gateway: publishing tx packet topic=“gateway/1c40e800403dfffe/tx”
INFO[0036] backend/gateway: gateway stats packet received mac=1c40e80081fefffe
INFO[0036] gateway updated mac=1c40e80081fefffe
INFO[0039] backend/gateway: gateway stats packet received mac=1c40e800403dfffe
INFO[0039] gateway updated mac=1c40e800403dfffe
INFO[0054] backend/gateway: rx packet received
2017/11/17 10:05:16 len(FHDR) = 9 fOptsLen=2
2017/11/17 10:05:17 len(FHDR) = 9 fOptsLen=2
INFO[0054] hello this is setContextFromDataPHYPayload func, ctx.phyload {{ConfirmedDataUp LoRaWANR1} 0xc4203767d0 2054500b}rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1080104332 471900000 2 1 1 4/5 -79 8.8 41 {LORA 8 125 0}}]
INFO[0054] hello this is getNodeSessionForDataUp func
INFO[0054] hello this is GetNodeSessionForPHYPayload func, {57f97cbf {true false false false 2} 77 [{LinkADRReq 0xc420375813}]}
INFO[0054] the FCnt is valid, validate the MIC
INFO[0054] micok = true err =
INFO[0054] hello this is logDataFramesCollected func
INFO[0054] packet(s) collected dev_eui=9bf728017a881379 gw_count=1 gw_macs=1c40e800403dfffe mtype=ConfirmedDataUp
INFO[0054] hello this is decryptFRMPayloadMACCommands func
INFO[0054] hello this is sendRXInfoToNetworkController func, rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1080104332 471900000 2 1 1 4/5 -79 8.8 41 {LORA 8 125 0}}]
INFO[0054] rx info sent to network-controller dev_eui=9bf728017a881379
INFO[0054] hello this is handleFOptsMACCommands func
INFO[0054] hello this is handleUplinkMACCommands func
INFO[0054] FOpts info cid=LinkADRReq dev_eui=9bf728017a881379 payload=&{true true true}
INFO[0054] printf Fpots key
INFO[0054] mac-command block removed from pending cid=LinkADRReq dev_eui=9bf728017a881379
INFO[0054] link_adr request acknowledged dev_eui=9bf728017a881379 dr=5 enabled_channels=[0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95] nb_trans=3 tx_power_idx=7
INFO[0054] hello this is handleFRMPayloadMACCommands func
INFO[0054] hello this is sendFRMPayloadToApplicationServer func
INFO[0054] hello this is handleChannelReconfiguration func
INFO[0054] hello this hs handleADR func
INFO[0054] hello this is setLastRXInfoSet func
INFO[0054] hello this is syncUplinkFCnt func
INFO[0054] hello this is saveNodeSession func
INFO[0054] node-session saved dev_addr=57f97cbf dev_eui=9bf728017a881379
INFO[0054] hello this is handleUplinkACK func
INFO[0054] hello this is handleDownlink func
INFO[0054] backend/gateway: publishing tx packet topic=“gateway/1c40e800403dfffe/tx”
INFO[0061] backend/gateway: rx packet received
2017/11/17 10:05:24 len(FHDR) = 7 fOptsLen=0
INFO[0061] hello this is setContextFromDataPHYPayload func, ctx.phyload {{ConfirmedDataUp LoRaWANR1} 0xc420377810 68a567e3}rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1087507604 473100000 6 0 1 4/5 -47 11.8 39 {LORA 8 125 0}}]
INFO[0061] hello this is getNodeSessionForDataUp func
INFO[0061] hello this is GetNodeSessionForPHYPayload func, {57f97cbf {true false false false 0} 78 []}
INFO[0061] the FCnt is valid, validate the MIC
INFO[0061] micok = true err =
INFO[0061] hello this is logDataFramesCollected func
INFO[0061] packet(s) collected dev_eui=9bf728017a881379 gw_count=1 gw_macs=1c40e800403dfffe mtype=ConfirmedDataUp
INFO[0062] hello this is decryptFRMPayloadMACCommands func
INFO[0062] hello this is sendRXInfoToNetworkController func, rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1087507604 473100000 6 0 1 4/5 -47 11.8 39 {LORA 8 125 0}}]
INFO[0062] rx info sent to network-controller dev_eui=9bf728017a881379
INFO[0062] hello this is handleFOptsMACCommands func
INFO[0062] hello this is handleFRMPayloadMACCommands func
INFO[0062] hello this is sendFRMPayloadToApplicationServer func
INFO[0062] hello this is handleChannelReconfiguration func
INFO[0062] hello this hs handleADR func
INFO[0062] hello this is setLastRXInfoSet func
INFO[0062] hello this is syncUplinkFCnt func
INFO[0062] hello this is saveNodeSession func
INFO[0062] node-session saved dev_addr=57f97cbf dev_eui=9bf728017a881379
INFO[0062] hello this is handleUplinkACK func
INFO[0062] hello this is handleDownlink func
INFO[0062] backend/gateway: publishing tx packet topic=“gateway/1c40e800403dfffe/tx”
INFO[0066] backend/gateway: gateway stats packet received mac=1c40e80081fefffe
INFO[0066] gateway updated mac=1c40e80081fefffe
INFO[0069] backend/gateway: gateway stats packet received mac=1c40e800403dfffe
INFO[0069] gateway updated mac=1c40e800403dfffe
INFO[0074] backend/gateway: rx packet received
2017/11/17 10:05:37 len(FHDR) = 7 fOptsLen=0
INFO[0075] hello this is setContextFromDataPHYPayload func, ctx.phyload {{ConfirmedDataUp LoRaWANR1} 0xc4203bcaa0 2e13ee44}rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1100672268 473300000 7 0 1 4/5 -48 11.5 39 {LORA 8 125 0}}]
INFO[0075] hello this is getNodeSessionForDataUp func
INFO[0075] hello this is GetNodeSessionForPHYPayload func, {57f97cbf {true false false false 0} 79 []}
INFO[0075] the FCnt is valid, validate the MIC
INFO[0075] micok = true err =
INFO[0075] hello this is logDataFramesCollected func
INFO[0075] packet(s) collected dev_eui=9bf728017a881379 gw_count=1 gw_macs=1c40e800403dfffe mtype=ConfirmedDataUp
INFO[0075] hello this is decryptFRMPayloadMACCommands func
INFO[0075] hello this is sendRXInfoToNetworkController func, rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1100672268 473300000 7 0 1 4/5 -48 11.5 39 {LORA 8 125 0}}]
INFO[0075] rx info sent to network-controller dev_eui=9bf728017a881379
INFO[0075] hello this is handleFOptsMACCommands func
INFO[0075] hello this is handleFRMPayloadMACCommands func
INFO[0075] hello this is sendFRMPayloadToApplicationServer func
INFO[0075] hello this is handleChannelReconfiguration func
INFO[0075] hello this hs handleADR func
INFO[0075] hello this is setLastRXInfoSet func
INFO[0075] hello this is syncUplinkFCnt func
INFO[0075] hello this is saveNodeSession func
INFO[0075] node-session saved dev_addr=57f97cbf dev_eui=9bf728017a881379
INFO[0075] hello this is handleUplinkACK func
INFO[0075] hello this is handleDownlink func
INFO[0075] backend/gateway: publishing tx packet topic=“gateway/1c40e800403dfffe/tx”
INFO[0081] backend/gateway: rx packet received
2017/11/17 10:05:44 len(FHDR) = 7 fOptsLen=0
INFO[0081] hello this is setContextFromDataPHYPayload func, ctx.phyload {{ConfirmedDataUp LoRaWANR1} 0xc4203bd810 cf87955c}rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1107399580 472500000 3 0 1 4/5 -42 10.8 39 {LORA 8 125 0}}]
INFO[0081] hello this is getNodeSessionForDataUp func
INFO[0081] hello this is GetNodeSessionForPHYPayload func, {57f97cbf {true false false false 0} 80 []}
INFO[0081] the FCnt is valid, validate the MIC
INFO[0081] micok = true err =
INFO[0081] hello this is logDataFramesCollected func
INFO[0081] packet(s) collected dev_eui=9bf728017a881379 gw_count=1 gw_macs=1c40e800403dfffe mtype=ConfirmedDataUp
INFO[0081] hello this is decryptFRMPayloadMACCommands func
INFO[0081] hello this is sendRXInfoToNetworkController func, rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1107399580 472500000 3 0 1 4/5 -42 10.8 39 {LORA 8 125 0}}]
INFO[0081] rx info sent to network-controller dev_eui=9bf728017a881379
INFO[0081] hello this is handleFOptsMACCommands func
INFO[0081] hello this is handleFRMPayloadMACCommands func
INFO[0081] hello this is sendFRMPayloadToApplicationServer func
INFO[0081] hello this is handleChannelReconfiguration func
INFO[0081] hello this hs handleADR func
INFO[0081] xxxxxxxxxxxxxxxxxxxxxx on HandleADR func
INFO[0081] LinkADRReq’s Payload CID=LinkADRReq ChMask=[true true true true true true true true true true true true true true true true] ChMaskCntl=0 DataRate=5 NbRep=3 TXPower=5
INFO[0081] mac-command block added to queue cid=LinkADRReq dev_eui=9bf728017a881379 frmpayload=false
INFO[0081] adr request added to mac-command queue dev_eui=9bf728017a881379 dr=4 nb_trans=3 req_dr=5 req_nb_trans=3 req_tx_power_idx=5 tx_power=0
INFO[0081] hello this is setLastRXInfoSet func
INFO[0081] hello this is syncUplinkFCnt func
INFO[0081] hello this is saveNodeSession func
INFO[0081] node-session saved dev_addr=57f97cbf dev_eui=9bf728017a881379
INFO[0081] hello this is handleUplinkACK func
INFO[0081] hello this is handleDownlink func
INFO[0082] pending mac-command block set cid=LinkADRReq commands=1 dev_eui=9bf728017a881379 frm_payload=false
INFO[0082] mac-command block removed from queue cid=LinkADRReq dev_eui=9bf728017a881379
INFO[0082] backend/gateway: publishing tx packet topic=“gateway/1c40e800403dfffe/tx”
INFO[0082] node-session saved dev_addr=57f97cbf dev_eui=9bf728017a881379
INFO[0096] backend/gateway: gateway stats packet received mac=1c40e80081fefffe
INFO[0096] gateway updated mac=1c40e80081fefffe
INFO[0099] backend/gateway: gateway stats packet received mac=1c40e800403dfffe
INFO[0099] gateway updated mac=1c40e800403dfffe
INFO[0102] backend/gateway: rx packet received
2017/11/17 10:06:05 len(FHDR) = 9 fOptsLen=2
INFO[0102] hello this is setContextFromDataPHYPayload func, ctx.phyload {{ConfirmedDataUp LoRaWANR1} 0xc42006a1e0 75cc1896}rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1128493468 473100000 6 0 1 4/5 -41 11.8 41 {LORA 8 125 0}} {1c40e80081fefffe 0001-01-01 00:00:00 +0000 UTC 3597501332 473100000 6 0 1 4/5 -107 -7.8 41 {LORA 8 125 0}}]
INFO[0102] hello this is getNodeSessionForDataUp func
INFO[0102] hello this is GetNodeSessionForPHYPayload func, {57f97cbf {true false false false 2} 81 [{LinkADRReq 0xc420014c53}]}
INFO[0102] the FCnt is valid, validate the MIC
INFO[0102] micok = true err =
INFO[0102] hello this is logDataFramesCollected func
INFO[0102] packet(s) collected dev_eui=9bf728017a881379 gw_count=2 gw_macs=“1c40e800403dfffe, 1c40e80081fefffe” mtype=ConfirmedDataUp
INFO[0102] hello this is decryptFRMPayloadMACCommands func
INFO[0102] hello this is sendRXInfoToNetworkController func, rxinfo [{1c40e800403dfffe 0001-01-01 00:00:00 +0000 UTC 1128493468 473100000 6 0 1 4/5 -41 11.8 41 {LORA 8 125 0}} {1c40e80081fefffe 0001-01-01 00:00:00 +0000 UTC 3597501332 473100000 6 0 1 4/5 -107 -7.8 41 {LORA 8 125 0}}]
INFO[0102] rx info sent to network-controller dev_eui=9bf728017a881379
INFO[0102] hello this is handleFOptsMACCommands func
INFO[0102] hello this is handleUplinkMACCommands func
INFO[0102] FOpts info cid=LinkADRReq dev_eui=9bf728017a881379 payload=&{true true true}
INFO[0102] printf Fpots key
INFO[0102] mac-command block removed from pending cid=LinkADRReq dev_eui=9bf728017a881379
INFO[0102] link_adr request acknowledged dev_eui=9bf728017a881379 dr=5 enabled_channels=[0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95] nb_trans=3 tx_power_idx=5
INFO[0102] hello this is handleFRMPayloadMACCommands func
INFO[0102] hello this is sendFRMPayloadToApplicationServer func
INFO[0102] hello this is handleChannelReconfiguration func
INFO[0102] hello this hs handleADR func
INFO[0102] hello this is setLastRXInfoSet func
INFO[0102] hello this is syncUplinkFCnt func
INFO[0102] hello this is saveNodeSession func
INFO[0102] node-session saved dev_addr=57f97cbf dev_eui=9bf728017a881379
